Question about Dell Inspiron 1501 Notebook
Computer wont turn on
When i press the power botton it only turns on a light with the letter a on it but wont do nothing else
  • vivian huertas May 04, 2010
    inspiron 1501
  • crveno
    crveno May 11, 2010
    And which PC ?
  • 721 Answers
Try an external monitor & see if you get anything. There's alot of reasons for this issue so post back with all the info you can that led up to this.
Posted on May 04, 2010
I try to turn my computer on but no luck, the little green light in the back is on, does that mean anything?
The green light indicates that the power supply is standby, if you press power botton and PC doesn't turn on, the simplest failure could be a defective power botton, also at the worst case you could have a defective power supply or motherboard.
Feb 18, 2011 | HP Hewlett Packard Pavilion Slimline...
My laptop wont turn on, the green light apears when I press the on botton and it sounds asif it's starting up, but then nothing happens, the screen stays black ?
If you have a desktop computer ,try connecting monitor cable to laptop,u may get the display.
It sounds like ur lcd or the inverter board has a problem.
Nov 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
The Fn botton on my vio lap top won't work
The Fn button is like a 'shift' key. Just as you would press <Shift> and a letter to get a capitalized letter, you press <Fn> and a function key at the same time ( <Fn><F1> or <Fn><F2> and so on) to use the secondary function for that key. For example, on one of my laptops, the <F2> key has an icon for 'wireless' (looks like an antenna). If I simply press <F2>, I will activate the function for <F2>, but if I press <Fn> and <F2> at the same time, I will turn on my wiress adapter.
<Fn> all by itself does nothing.
Hope this helps.
Oct 08, 2009 | Sony Computers & Internet
ASpire one Acer wont turn on.
Pretty new system, so try on just AC power (remove battery) failing that, get in touch with Acer for repair under warranty
Jun 29, 2009 | Acer Aspire 5100 Notebook
Computer did not power up after re-imaging
remove your RAM and processor.......then turn on ur PC...it will gave you different beeps...then again install ur RAM and processor... ur problem will solved
Mar 09, 2009 | Computers & Internet
Hibernating I guess
boot your computer in safe mode and in display properties>Screensaver>Power tab>Advance>
"When i press the power botton on my computer " select "do nothing" and " when i press the sleep botton on my computer " select "do nothing"......
then press ok and apply then restart your computer in normal mode it will work
Jun 12, 2008 | HP Compaq dc7100 PC Desktop
Dell Inspiron 1501 Notebook Logo
48 people viewed this question
Alun Cox
