Question about Dell Dimension 4600 PC Desktop
Wireless mouse will not work , but the light is
Wireless mouse will not work , but the light is on.
  • 721 Answers
Re-install the mouse driver.
Posted on May 04, 2010
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
Wireless USB works, but mouse itself doesn't
Sir/Mam good day,
Is your mouse device also wireless? you need to resync it with it's receiver,
you may follow the methods below to make your wireless usb mouse works.
You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
and can't be reset. If your devices don't have a button, here's what to do:
If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
to do this:
press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
the same you need to repeat the previous steps once again.
As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
released. You can use a pencil or anything with a sharp point to released it.
There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
*Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
and see if it will work.
*And also the cables that are included with the wireless receiver, try to use another cables if the
device is still not working.
*If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
the available ports on your pc and see if it will work.
*When fixing this type of problem you need to have only one usb device
connected to your computer, which is in this case, your usb wireless mouse.
*When you have other usb devices, you need to
plug it out.
*If the methods mentioned previously still won't work, you need to reinsert your
wireless mouse batteries or install a new one.
*Another possible remedy to this problem is checking the interference, your wireless
usb mouse together with its receiver should be a distance away from anything that
transmits signals such as cellphones, radios or other similar devices. And also
any metal objects. because such things might interfere with the signal of your
wireless mouse.
* If the problem persists after doing all of the above steps, maybe it's time to update
your wireless mouse drivers, For installing latest driver update with your wireless
mouse, see the documentation that is included in your wireless mouse.
* If all of the methods above did not solve your wireless mouse problem. You can
connect your wireless mouse to another working computer to see whether the problem
lies with your wireless mouse or to the computer which your wireless mouse is
connected.
Final instruction:
If all of these methods fail, you better have your wireless usb mouse be check
by a professional computer technician in order not to further damage your device.
Hope this helps. Good luck and God bless
http://online-pcrepair.blogspot.com/
Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
Wireless mouse stopped working
REINSTALLING WINDOW MIGHT HAVE OVERCOME THIS PROBLEM. GO TO CONTROL PANNEL, WIRELESS WIZARD THEN PROCEDD. SET A WIRELESS CONNECTION, SELECT MOUSE THAN PROCEED
Dec 12, 2009 | Computers & Internet
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
I have tried 3 fresh, new batteries
What is the exact model of wireless mouse you have? You may have a laser wireless mouse, which may not emit any visible light. The red light on other wireless mice are either a different optical mouse technology, or a red light for the purpose of being pretty. Not all wireless mice have a red light that you can see. Does the mouse work (regardless of the light)? Have you hit the connect button? Have you connected the wireless receiver to a working USB port?
Jul 18, 2009 | Microsoft Wireless Notebook Optical Mouse...
HP wireless mouse
Try replacing the batteries. Wireless mice do funky things when the batteries are low.
May 18, 2009 | HP Wireless Optical Mouse
Wireless keyboard numbers on right not working and wireless mouse light not on
My Dell wireless keyboard doesn't work. I replaced the batteries in it and pressed the green button on the back of it then the button on the wireless thing plugged into the computer. That light blinks for a few seconds then stops but the keyboard still doesn't work. My wireless mouse works fine.
Oct 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Wireless mouse quit working
remoove the mouse cover and check the main led .most common fault is burnt out l e d.
nuwan
Sep 28, 2008 | Microsoft Wireless Notebook Optical Mouse...
GE Wireless mouse & keyboard
are both keyboard and mouse communicating with a single wireless devices, or each has it's own? sometime you need to sync the signal to the wireless device. but do this first... ask your sister if the mouse was working before she gave it to you, there is a possibility that the mouse is broken/no working. if it's an optical mouse, the mouse that has lights sensor, make sure it lights up...
Feb 16, 2008 | GE Wireless Optical Mini Mouse 3087897985
Re: wireless mouse doesn't work
my wireless mouse has packed up the light is on ive tried new batteries what else can i try
May 25, 2007 | Impression Products Impression M1 Wireless...
Dell Dimension 4600 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
