Question about Prime 10 Amp Circuit Breaker
Stair case wiring circuit - Prime 10 Amp Circuit Breaker
    Guru:
  • 351 Answers
Could you describe your situation a bit more detail? are you asking about 3 way switching on a stairway?
Please vote !!
Posted on May 12, 2010
  • raghavverma Jun 19, 2011
    its awesome man...... This switch is very use full.....
Replaced a ceiling fan controlled by 2 wall switches that had red, black and white wires. The FanimationPalisade switch has 2 black wires and a ground wire. How can I connect and keep 3 way operation?
You can't because the new controller is not Two Way which is like the switches you have at the top and bottom of stairs. In my experience there is no such thing as a 3 way switch, only one way and two way.
On a one way switch, you have one wire in and one wire out plus ground. On a two way you have an extra bridge connection which completes the circuit from the other end.
This shows the circuit in relation to stair lights, but your fan circuit is the same.
http://2.bp.blogspot.com/-fEGWhPG3cB4/UJ5duBXNp-I/AAAAAAAAAUk/qOmIBJ8AfDQ/s1600/Stair+case+wiring+circuit+diagram%252C+OR+How+to+control+a+lamp+from+two+places+by+two+2+way+switches.JPG
Aug 20, 2016 | Dryers
Tip
The Function Of Aluminum Stair Nosing
Stair Nosing is also named as stair edging, it's a popular type of material for stair installation. Now a day, aluminum stair edging is widely used in our daily lives, such as shopping malls, office buildings, hospital, residence, villa and so on.
Regarding its function, stair nosing can greatly reduce the slipping accident of stairs, in addition, it can make the stair cases with stunning trims, and protect the edge of stair tiles and parquets from cracking.
As the density of aluminum alloy is literally low with high strength that is close to stainless steel, so aluminum stair edging has excellent electrical & thermal conductivity, and also featured with corrosion resistance. Compared with wooden & plastic edging bar, the surface of aluminum ally can be made with a variety of finishes, so we can have rich options of colors of it, and it also has many other features such as wear-resistant, anti-aging, anti-bacterial, flame retardant, non-toxic etc., not only that, its price is very reasonable to be widely used and loved by the users, and has particularly prospects on the market.
on Apr 03, 2017 | Building Materials
Where is the circuit breaker on a electric cooker
The circuit breaker is in your home somewhere, usually in the basement in a box fixed to the wall. There are no breakers in the stove itself. You call it a 'cooker', so if you are in the uk the breaker will be under the stairs or in the garage.
Dec 17, 2015 | Electric Electrical Supplies
My daughter recently moved into a house built in 1971. She had the ceiling lights on down stairs. When she plugged the vacuum cleaner into an outlet n the same room, all the lights went dull. Now t
I'd be looking for a loose screw that holds the wire to the circuit breaker. If they all are tight then there is a loose wire nut somewhere in the circuit. You'll need to open every switch and socket in the room to find it. Don't ignore it or put it off as a fire could easily start at the point where the wires have a poor connection.
Jan 01, 2015 | Electrical Supplies
Need to remove prop on T29
I believe you are referring to a 3-way switch.
( 2 switches that operate the same light, like the
ones used at the top and bottom of stairs)
Oct 04, 2013 | Electrical Supplies
How to wire a two way switch for a stair
1) Copy following link for 3-way switch wiring:
http://waterheatertimer.org/How-to-wire-switches.html#3-way
2) Add a comment March 2013 for more assistance.
Mar 15, 2013 | Prime 10 Amp Circuit Breaker
Breaker keeps tripping on the machine
Open the right side panel and look at the wiring coming through from the bottom outside panel. Move the stairs by hand and see if the corner of the stair touches the wires coming through the from the bottom panel. If so your chains have stretched and need to be adjusted. The wire harness will also need to be replaced.
Apr 28, 2009 | Stairmaster Stepmill 7000 Pt
Measuring for stair carpet
measure the length of the tread and riser, combined. Typically this will be 17 inches or so. Add at least an inch or two for good measure then, assuming all the stairs are the same, multiply by the number of stairs and, in most cases add for one additional riser. This is for straight stairs with no landings or turns. For pie-shaped stairs one needs to measure the longest points for the trad portions.
Sep 03, 2008 | Office Equipment & Supplies
Speaker Wires
The wires that feed the speaker are usually attached on the back of the conical part of the speaker. They are usually soldered on two terminals.
Hope it helps.
Mar 08, 2008 | Grundig G4000A FM/AM Radio
Prime 10 Amp Circuit Breaker Logo
3,081 people viewed this question
Top Prime Electrical Supplies Experts
Gene Haynes
Jim London
Jim London
Steve
Are you a Prime Electrical Supply Expert? Answer questions, earn points and help others
