Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
How do i switch from hot to cool - Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
  • 674 Answers
There should be a mode button on the thermostat that will switch it. If its not labeled press a couple of them til you find the right one.
Posted on May 04, 2010
PTAC UNIT BLOWING HOT AIR IN COOLING MODE
Hot or warm? Sound like float switch shuts compressor off. Vacuum the drain and clean the pan
Aug 24, 2016 | Heating & Cooling
What color are the hot wires on my cooling fan switch for my 2001 Oldsmobile intrigue
This is for the manual controls and not the automatic. If you need the automatic, let me know
Nov 14, 2015 | 2001 Oldsmobile Intrigue
Car gets hot when Idle
You might check your cooling fan at the radiator; it may not be running. If it's not, track it down (fuse or thermal switch) and fix it!
Aug 07, 2014 | 2007 Suzuki XL7 AWD
Will not switch off
make sure the one that says "cool, hot, and off" is switched to off.
Mar 02, 2014 | WHITE-RODGERS DIV 1F56N-444 Universal...
Cooling fan switch
It is not necessary to replace the thermo-switch when replacing the radiator. The switch can be replaced separately.
The fan switch is located under the sound box of the air cleaner. It is 2 pin connector. Pull the connector out by pressing the lock which attached to it and short the two pins with a thin auto wire temporarily. Switch on the ignition. The fan will become on. Drive it and see if runs hot.
If the temp reads OK, replace the fan switch. If the problem persists, diagnose the other issues which are concerned with the overheating problems.
May 07, 2013 | 2003 Honda Civic
Furnace switches to auxiliary heat while in cool
It's likely a bad tstat. Turn the power off to your air handler. Remove red , green, yellow and orange wires inside the tstat and wire nut them together. Not sure if your reversing valve energizes in heating or cooling but, turn the power back on. If the unit is heating turn the power off and remove just the orange wire and turn power back on. Let this run and see if it you are ONLY getting cool air ALL the time. If so you have a bad stat. If still getting heat possibly you have a bad control board in the air handler. Good Luck!!
Apr 15, 2017 | Honeywell Heating & Cooling
2000 buick lesabre Heat control will not switch
their is a little motor on your duct work that moves a door open and closed to switch from heat to cool,it is called actuator motor.watch it and have someone to switch it from cool to heat to Se if the motor is turning.
Oct 10, 2009 | 2000 Buick LeSabre
My honda v65 magna runs hot in stop and go traffic
V65s are notorious for running hot in stop and go traffic as it has a liquid coolant system and no cooling fins on the heads or cylinders. An easy fix is to wire in a switch to turn on your electric radiator cooling fan and switch the fan on and leave it on when you are riding in town.
May 05, 2009 | 1984 Honda VF 1100 C
My Waring Pro Ice Maker is not cooling. The water pumps through the system but the machine does not freeze. The machine is 18 months old.
JUST SWITCH ON YOUR ICE MAKER AND TOUCH THE COOLING SIDE HOT OR COOL ,
1st . COOLING SIDE IS HOT THE MACHINE COMPRESSOR IS FAULT REPLACE THE COMPRESSOR
2nd. COOLING SIDE IS JUST COOLING CLEAN MACHINE CONDENSER COIL
Jul 19, 2008 | Refrigerators
Heating & Cooling Logo
26 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
