Question about StarTech.com StarView SV211K 2-port KVM Switch
Service unknown some of the channals don t come up now and says service unknown
Hy how can i unlock all channals of asiaset3s and panamsat 7,i live in pakistan
brother you can't unlock asiasat and panamasat channals. the only which possible is unlocking hotbird
Mar 14, 2011 | Computers & Internet
We purchased the midland two way radio, the problem is the channel we are on we only can hear every one in our group, but can not communicate if they are on their radio. How can we get on the same...
You should ask the others what channals they are on if you cant for whatever reason then scan for a frequincy that has others on it by hitting the scan butten and hitting the channal up or channal down butten, if you can tthen talk on each channal in order and wait 10 seconds for a reply then go to another channal and try agean, im not sure if you can hear others unless they have the same brand radio's but i could be wrong, i am also not sure if the scan butten will work so after it goes through all of the channals 2 times then try the other suggestion. you also want to make sure you have good batteries in when you try.
Hope this helps
Gamer71796
Feb 14, 2011 | Midland Two Way Radio
I cant get the sirius to go past channal 39 it is telling me that the channales are preset. i dont have the manual for the stero so i dont know how to get all the channals to work.
  • [P/A] button Performs category scan while in the SIRIUS mode.When the button is pressed and held, preset scan is performed.
  • [DIRECT] buttons Stores a station into memory or recall it directly while in the SIRIUS mode.
  • [ > '' ] (play/pause) button Select a category [<<] rewind, [>>] fast forward button Press the button to select a station.
  • [FNC] button Press the button to switch the operation mode among the SIRIUS mode, etc.
Nov 17, 2010 | Clarion DXZ845MC CD Player
Need instructions to program tv
okay this is what you do hit the code search botton hit the tv botton the hit channal up untell you find that your tv is changing channals then hit tv again and that should work just do it slow becouse if you pass the channal it changes then you will have to use the channal back button tell it pops up again it will work.
Dec 09, 2009 | RCA Universal Remote Control
Hi i have a tv from a hotel and it will only turn to some channals not all how can i reset the channals
i believe youre gonna need the remote control , what brand and model ?? AJ
Nov 20, 2009 | RCA F32648 32" TV
Coby tf-tv700 a 7in lcd tv will not git channals since diggital s
Go to menu pick rescan channels,not getting more channels,get digital antena.Rescan again.
Aug 15, 2009 | Coby TF-TV700 7 in. Portable Television
Info service
Go to the Messages and then tap on info service and add the new channel with value 50. it will work now.
Thanks,
Rajendra
Nov 28, 2008 | Motorola Mobility ROKR E6 Smartphone
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Oct 26, 2008 | Home Security
HELP!!!
Go back in the menu, find (input source) or (tuner) then click the cursor right side of the menu button or the left to move the (TV) to (CATV), after you bring it up then move cursor arrow up or down to page (AUTOPROGRAM) then tap the cursor arrow right of the menu button to start the CATV channels to be found , be sure you have the cable connected to the TV. Once the channels have been found, tap (EXIT) or (STATUS) button on remote to get out of the menu and close the page, or just turn set off and back on again.
May 29, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Channal Search
Im sorry but you can't without the original remote. If you want to consider getting the remote go to http://www.remote.com or maybe you can borrow one from a freind or a local store that sells Emerson will let you borrow one. Good Luck
Aug 13, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
StarTech.com StarView SV211K 2-port KVM Switch Logo
57 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
