Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma IP3000 6C00 Logic Board Assembly repair?
I have the 6C00 error on my ip3000. IS there any 'cheat' to fixing the problem? I've heard it's a valve purge error or something and I'm fairly handy with a screwdriver. Is there anything to do for someone who believes in the "Duct Tape and Garbage can build anything A-Team" motto?
  • 3 more comments
  • pdrayton Mar 26, 2008
    Thanks Cropp. I'll try that tonight when I get home. IF it fixes it I'll be way pleased.
    I'm at saffir at gmail dot com.
    Cropp, that didn't work. Holding the power on and pressing resume doesn't change the LED color. Are you sure that is for the IP3000?
    Here's the correct procedure (at least it worked as it said it would for me)
    Pixma IP3000
    1. Turn off printer.
    2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
    3. let go button Resume/Cancel, continuing to retain POWER.
    4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
    5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
    6. turn off printer by button POWER.
  • scotty2h0tty May 11, 2010
    all i did was change the USB cable in to a USB2 port, instead of usb 1.
    Now it is working fine again. ;-)
    - so weird.
  • Eva Eva Jul 25, 2013
    IT WORKS FOR ME TOO! THANKS
Pixma ip3000 is not turning on
Posted on Mar 01, 2010
    Guru:
  • 377 Answers
Hi dear
many problem that canon has give to us, but let me to try to give some advice for you
the trick is
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
and for the tool program i send you'll later after i receive your e-mail
just send me your email
oke
but i hope the trick can solve your problem
cropp
Posted on Mar 26, 2008
6300 error code
Alarm LED lit
RAM error [6300] The RAM error occurred in the RAM check at hard-power-on.
Its a hardware error. In most case the logic board assembly is failed or an internal error of one of the ASIC chips on the logic board and can be repaired by replacing the logic board at the Canon Service Center.
Feb 18, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5200
Print head temperature rise error [5200] - Print head (QY6-0042)
- Logic board ***'y (QM2-1520)
Before replacement of the logic board ***'y, check the waste ink amount (by service test print or
EEPROM information print). If the waste ink amount is 7% or more, also replace the bottom case unit
(QM2-1249) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864) when replacing the
logic board ***'y. See 4. SERVICE MODE, for details.
Dec 02, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Hello, I have an canon 3000 printer, and I keep getting a service error 6A00. I've turned the printer on and off. We've also unplugged everything, but it still does it. Do you know the problem?
Error:
AP position error [6A00]
Solution (Replacement of listed parts, which are likely
to be faulty):
- Sheet feed unit (QM2-1220)
Oct 13, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Ip 3000 canon showing service error 5100, tried to reset but still flashes amber. Tried nearly everything. Cartridges still full
Carriage error [5100]
to be faulty):
- Carriage unit (QM2-1250)
- Timing **** strip film (QC1-4284)
- Logic board ***'y (QM2-1520)*1
- Carriage motor (QK1-0545)
Aug 04, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Error code 6500
Error 6500 is a hardware error.In most case the logic board assembly is failed or an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
Please rate your response.
Thanks, SF
Feb 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have a acanon pixma mp210.. amber alarm light
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Fault/error 6A00 for my canon MP830 flash light and no paper (fault) roller defect can I fix this ? John
6A00 is AP position error.Possible problems in:
- Logic board assembly (QM2-1520)
Oct 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error 6A00
6A00 is AP position error. Check sheet feed unit.In worst case the logic board assembly is defective.
Mar 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma ip3000 flashing amber 6 times
If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
This code indicates the following;
Internal temperature error [5400]
The solution to this is the following part replacementl
- Logic board ***'y (QM2-1548) *1
*1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
logic board ***'y.
[See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
Good luck!!!
Jan 12, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error message
If it really is a "logic board" problem, then it's time to responsibly recycle the printer, and to purchase a brand-new printer; hopefully, you can find one that uses the same ink-cartridges as your current printer.
A "pro" would charge you $50 to $100 to _look_ at it, with _no_ guarantee of being able to fix it; instead, invest that money in the new printer, which you _know_ will work.
Sep 19, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
2,566 people viewed this question
old marine
old marine
