Question about Sony VPL-EX1 Multimedia Projector
How do i get rid of replace lamp message & reset lamp timer
I have a problem in getting rid of the replace lamp message and to reset the lamp timer, however i do have the remote but there seem to be no option for that.
  • juda_kwt Mar 26, 2008
    Hello Marrie,
    Sorry i tried with the remote RM-PJ2 but it does not seem to respond. The problem still exists
    Jude
  • juda_kwt Apr 02, 2008
    Thanks Marie, apparently i am not able to get both left and right arrow since the button is like a joystick round key , please advise.
    Jude
If you are using the RM-PJ2 remote control, following these instructions. You will have 5 seconds to complete the key sequence.
1. Make sure the Projector is in "Standby" mode. There will be a red light instead of green
2. Press the Reset button
3. On the "joystick" type button, toggle the left directional arrow
4. On the "joystick" type button, toggle the right directional arrow
5. Press down on the "joystick" button to press Enter.
6. Your lamp hours should now be reset.
Recap: Reset, left arrow, right arrow, Enter, all within 5 seconds.
Posted on May 05, 2010
  • 563 Answers
Hi there
You should hold down the left & right scroll buttons on the remote and press menu. That will reset the lamp timer.
Posted on Mar 26, 2008
  • Marnus Jacobs
    Marnus Jacobs Mar 27, 2008
    Hi there
    Make sure the Projector is in standby mode - in other words take out the power cable and plug it back in - now it is in standby mode.
    Hold down the left and right buttons on your remote and press enter.
    Sorry I see that I said menu on my previous posting. It should be Enter.
    Hope this helps you !
Reset the message "The lamp and filters need replacing"
do you have a remote with this?
follow manufactuer guide to reset the timer
Nov 03, 2011 | HEWLETT-PACKARD Designjet 4500 PassThrough...
Tip
How to reset the lamp timer on Sony Projection TVs.
If you have replaced the lamp in your Sony projection TV you must reset the lamp timer to get rid of the message saying that your lamp needs to be replaced. Let's face it, you know you already accomplished replacing the lamp but the TV isn't smart enough to know that. I will explain in detail how to accomplish the reset procedure.
Resetting the lamp timer is a complicated procedure but you should be able to do it if you have plenty of patience and know how to follow instructions. Read the procedure over first several times before trying to do it and locate all the buttons on the remote. You may want to try the procedure on the remote to make sure that you have the sequence memorized.
By the way the lamp life is figured to be from 5000 to 8000 hours. That is not much time if the TV is being used for more than 8 hours per day. If you do the math and watch your TV for 8 hours per day (not uncommon) the lamp will need replaced in 3 to 5 years. So be ready to do this procedure again in the very near future.
Here is the procedure.
All commands should be done using the factory remote:
1) enter the service mode by pressing display, 5, volume +, Power on
2) press JUMP 3 times
3) to display the time press channel 2, 9 times
4) to reset lamp timer press channel 3, MUTE, Enter
5) to check the time press channel 1, 7 times
6) when complete turn set off to exit.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Oct 30, 2010 | Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    I replaced the lamp, but am unable to reset the lamp so that the projector works again. It keeps giving me the message that I need to replace lamp and reset timer. And then it turns off.
    1. Switch power ON, and press the TIMER button on the remote controller, or the RESET button
    on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear
    2. Press the MENU button on the remote controller, or the RESET button on the control panel,
    while the lamp timer is displayed. The 'LAMP xxxx ? 0 CANCEL' message will then
    appear.
    3. Press the and select 0, and wait until the timer display is cleared.
    Feb 18, 2011 | Hitachi CP-X270 Multimedia Projector
    I have a large screen panasonic tv. The lamp
    Turn On tv.
    Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
    Hope this info will help you.
    Thanks.
    Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
    The person I purchased this t.v from is saying the lamp was just replaced, but the FINAL WARNING REPLACE BULB AND RESET TIMER message pops up every time I power the tv on. She said she forgot to reset the...
    If the timer has not been reset telling the unit it has a new lamp you will get that message. Call a servicer to find out how to reset the timer if you don't have the owners manual. If the message continues after that you will need to purchace a new lamp. There are problems that accur with some aftermarket lamps.
    Sep 21, 2009 | Televison & Video
    Sony vpl-hs20 cineza projector- reset lamp counter
    These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
    1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
    Connect the power and set the projector to standby mode.
    Press these buttons on the remote control in this order, for less than 5 seconds each.
    Reset - Left Arrow - Right Arrow - Enter
    This is required, to reset the lamp timer.
    Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
    Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
    Replacing the projection lamp
    Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
    1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
    2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
    3. Press the remote 3 button, mute, then enter to reset the timer to zero.
    It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
    Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Projection lamp timer reset
    I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
    Jul 19, 2008 | Panasonic PT-44LCX65 Television
    Lamp Timer Reset...
    Hello, does any1 know how to reset the lamp timer on a LG RD-JT31? I want to get rid of the Replace The Lamp sign.
    Regards Linus
    May 12, 2008 | Office Equipment & Supplies
    Sony VPL-EX1 Multimedia Projector Logo
    1,018 people viewed this question
    Top Sony Office Equipment & Supplies Experts
    shaun taylor
    Jaime Hernandez
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
