Just bought bush headphones HS-301E USB for my P C placed usb connection in usb port pc reconized hardware but when i came to reduce the volume nothing happened
    President:
  • 1,851 Answers
You need to update your drivers and - select the headphones as your primary listening device. Go into CONTROL PANEL - SOUNDS - select your device - it might say USB sound or something with USB or usb in it. Select that as your default sound and you should be good to go.
Gary
Posted on May 05, 2010
The headphones don't work on my PC when plugged in to any of the USB ports they are very distorted and are very crackly.
Do you get a good sound from your PC using other headphone? Mean, are you sure you don't have a problem with your PC's audio card?
Jun 27, 2015 | Creative Labs ChatMax HS-720 Headset -...
How do i find out what kind of sound card to get for an acer aspire notebook 5315 series. It was bought at a yard sale and has windows 7 on it. Everything works but the sound
Hi Bonnie,
You should check Windows 7 Control Panel's device manager. See if the sound is disabled or if it indicates that it "has a problem" Try to re-enable it - or failing that - uninstall the sound card and click the box that says "remove files". Reboot with an internet connection (wifi or wired). Let windows detect the "new" sound hardware. Check any hardware volume control and set to a mid - high level point. After Windows downloads and installs the driver - follow instructions - reboot if asked. Then test the sound. Check software volume controls in control panel and verify that the sound is enabled. Try using the headphone jack if internal speakers are not producing sound. Once sure that the sound card is loaded, enabled and volume is set to mid - high and neither the internal speakers or external headphone do NOT work, you can consider selecting a new sound source that can use a USB port or PCMCIA (PC Card Slot) depending on your needs and port / slot availability on the laptop. Links below for both styles. Good luck!
pcmcia sound card Google Search
USB sound card Google Search
Apr 09, 2015 | Acer Aspire 5315 Notebook
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
My portable hard drive was working . Then one day it would not reconize my hard drive anymore ? How do I fix this ?
Try to boot in bios and reset defaults.Connect drive in different usb ports and check. Check usb cables. Try to do system restore.
Aug 18, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
Not able to increse volume.The volume controller on my laptop automatically slides down even if I increase it while using the headphone.
your head phone volume controller /speaker/s has been short circuited so please replace /purchase new headphone
thank you
May 24, 2009 | Logitech ClearChat Pro USB Headset
Please please help me
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jun 01, 2008 | SanDisk Sansa m250 MP3 Player
Ilo mp3
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 19, 2008 | iLO (2 GB) MP3 Player
ILO not reconized
Apr 04, 2008 | iLO (2 GB) MP3 Player
Sync
Oct 14, 2007 | iLO (2 GB) MP3 Player
Computers & Internet Logo
401 people viewed this question
David Payne
David Payne
