Question about Dell Inspiron 9300 PC Notebook
I replaced my HD on Dell inspiron 9300 and it won't recognize the new drive. The new drive was also purchased from Dell and was one that was compatible with the computer. It's saying there's no bootable HD even when I return the HD to #1 in the BIOS
  • 1 more comment
  • hjack May 04, 2010
    I had the windows dink in the CD Drive. It won't find the HD to install windows. Won't even get to the point to create a partition.
    I just removed the HD that Dell said was compatible by entering my Service Tag # and it is smaller. I don't think the pins are reaching far enough in. Enough of a difference that the entire size of the new HD (including pins) is equal to the size of the old one not including pins. Going to call Dell now.
    oops.... disk
    no, the pins are not even the same. The orig has pins all the way across & the new one have a break in them & blocked off with plastic that is molded on.
    Guru:
  • Dell Master
  • 1,705 Answers
It probably has found your new HD, you need watch the screen as you attempt to boot. Failing that enter the bios (usually " hit DEL to enter setup" appears on the screen. Don't change anything but just check to see if the bios has detected a hard drive.
Now .......... the reason why it won't boot is because you have to re-install windows onto the hard drive.
Posted on May 04, 2010
  • dgsturt May 04, 2010
    I've just had a look at Dell's instructions and there's no picture of the HDD interface.
    Dell have a happy knack of using proprietary interfaces with their products.
    Without seeing what you're dealing with, I don't think I can help further other than to say, nearly all connections are key coded, ie they can only connect 1 way.
    So are the connectors the same, in the right way and fully home ?
    Good luck.
  • dgsturt May 05, 2010
    They've sent you the wrong drive, they've sent one with a SATA interfacy, you need one with the older PATA interface.
My Dell 9300 screen is cracked and "black marks" are leaking down from the top. How can I replace it?
You can follow the link below that would help you to replace the LCD . The only thing to keep in mind is to keep a track of all the screws that would be coming out rest is easy .
Service manual Link
You can purchase the LCD, by calling Dell directly or from various online stores
1. http://www.parts-people.com/index.php?action=category&id=141&subid=75&refine=lcd%20screen
2.http://www.laptoppartsexpert.com/c-43742-dell-inspiron.html
Thanks for using Fixya
Proton
Oct 14, 2010 | Dell Inspiron 9300 PC Notebook
My Inspiron 9300 touchpad needs replacing
This is not a do it yourself repair, best sent to repair shop or back to factory to have it replaced
Oct 28, 2009 | Dell Inspiron 9300 Notebook
Can I add memory to a 9300 dell inspiron? Presently I only have 50g. Is it difficult to perform?
yes u can extend it by external Hard disk.
I think not possible to configure ur hardware configuration
Jun 16, 2009 | Dell Inspiron 9300 PC Notebook
My computer will not recognize the battery. Runs OK on AC.
Since the system is not seeing the batteries the apparent fault is the motherboard connection for the battery. If under warranty , contact Dell, in not, you can try and purchase a replacement motherboard on EBay.
Apr 26, 2009 | Dell Inspiron 9300 PC Notebook
Trouble with Secure Digital I/O slot on a dell laptop inspiron
go to google and look for SD card driver for xp, after you load the driver you will be fine.
Mar 24, 2009 | Dell Inspiron 9300 PC Notebook
PC wont boot to windows xp
This seems to Be a common problem with dells, The only way to fix it is to buy a new HD, And all data is Unrecoverable. Sorry for your loss
Jan 11, 2009 | Dell Inspiron 9300 Notebook
Removing CD drive on dell inspiron 9300
while the PC is on eject the DVD tray and turn off the computer, underneath the laptop you should find a screw which is holding it in place, when you find the correct screw and unscrewed it pull gently on the DVD and it should slide out, put your new one in and replace the screw, job done :)
regards an please don't forget to rate us
Dec 09, 2008 | Dell Inspiron 9300 PC Notebook
Is this locked with a bios or Windows password, and is this a new or used machine?
Jul 23, 2008 | Dell Inspiron 9300 Notebook
DST Error (1000-0146)
This error is a hard drive failure, your only option is to replace it and reload your operating system. It's easy to replace, the hard drive is located on the side of the machine and is held by one screw. After you get it out, the rest is self explanitory. Here's a link that shows breakdown diagrams.
http://repair4laptop.org/notebook.html
Jun 24, 2008 | Dell Inspiron 9300 Notebook
Dell Inspiron 9300 PC Notebook Logo
94 people viewed this question
Alun Cox
