Hi John, FixYa doesn't suplly any products or parts. This is an online community of experts who help users fix their product related problems. For your Dualit toaster, you might want to check the Dualit website: http://www.dualit.com/support Hope that helps
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Try ebay, their good price and they will come to you fast and on low cost. The midle one is called "CENTER" and the one at the two ends called "END"
Good Luck
Inside your toaster there are four heating element plates two in the center and one in left end and one in right end. Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END" They can easily be removed if you remove the bottom panel. Good Luck
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end. Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END" They can easily be removed if you remove the bottom panel. Good Luck
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end. Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END" They can easily be removed if you remove the bottom panel. Good Luck
You can get any part you need at the Dualit Repair Center: Electra-Craft 41 Woodbine St Bergenfield NJ 07621 phone 201-439-1700 fax 201-439-1701 [email protected] www.electra-craft.com
