Question about Samsung RB215LASH
Freezer not cooling and refrigerator cooling sometimes, but not consistently. I unpllugged the refrigerator/freezer for a minute or so and plugged it back in and it is now cooling somewhat. Does this indicate an electronics problem or a sealed system problem?
  • Samsung Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
j
Posted on Sep 30, 2010
This is for a kenmore top mount Refrigerator/Freezer Model Number 25363712302. Refrigerator was not cooling properly - was warm. Freezer was working, but after a couple of days, freezer also started to...
Since you say that is isn't cooling properly, I would first start off by cleaning the condenser grill that is located under the cabinet. While this won't correct your problem entirely, it will help!
Most likely you have a defrost system malfuntion. The defrost system consists of the defrost heater (p/n: 5303918208) which is the long tube like thing that sits directly below your evaporator behind the panel in the back of the freezer (inside the freezer). It also consists of the defrost thermostat (p/n: 5303918202), which is located next to the evaporator. Both the defrost heater and defrost thermostat can be checked with an ohm meter - a non-open/infinity reading is good. If both of those check out and are good then it has to be the defrost timer (p/n: 215846602) which is located behind the plastic shield (with the light bulb).
Suggest you defrost the unit (making sure no ice or frost is behind the freezer panel then plug the refrigerator back in. If everything cools down then my diagnosis is correct and one of the components of the defrost system is bad.
Oct 03, 2011 | Kenmore Top Freezer Refrigerator
Freezer cold, refrigerator sometimes cold sometimes hot
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | GE Profile Stainless Bottom-Freezer...
The refrigerator side does not consistently cool.
heatman101
Apr 26, 2011 | Refrigerators
My Subzero 650 does not stay on 34 degrees consistently. It is not now and I have turned the unit off for 15 minutes but to no avail. It has done this before but after a 36-48 hours it is back to 34...
aHi,
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Apr 23, 2011 | Sub-Zero Refrigerators
Fridge and freezer is stuck on defrost, what do I do?
Un plug it for a bit and then restart it....or a well placed whaap with your hand right by the timer may do it...
but sometimes it will not go and you will need to either manually turn it or get it replaced...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jan 11, 2011 | GE Microwave Ovens
Is there a reset on my refrigerator?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Pull the plug and then plug it back in in a few minutes....
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerator and freezer temperature control
hi. thanks for te question. since you asked the question. has your fridge settled down and cooling sometimes the fridge will set itself
Sep 24, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Roper Fridge
You have one of the following problems which is indicated by the frost buildup. Your defrost timer has failed, or defrost heater circuit consisting of a defrost heater and defrost thermostat. Start at the defrost timer. May be located in the fridge compartment near the temperature controls. There may be a recess through which you can turn the dial SLOWLY clockwise until you hear one click. the freezer will be in defrost. Wait 18-22 minutes and the freezer should defrost and restart into cooling. If it does not restart after 30 minutes turn the screw clockwise again one more click and it should restart.
If you had to turn it again to get it to restart the timer is bad and needs to be replaced. If the timer restarted the cooling mode after 18-22 minutes and defrost did not take place your problem is in the heater circuit.
Jun 09, 2008 | Roper Refrigerators
Samsung RB215LASH Logo
103 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
