Question about Amana NAV5805A Top Load Washer
My amana washer top load
I have a top load amana washer,it was working fine until acouple uf days ago.It started to spin the water out then it stopped.Then a couple of minutes it started back trying to spin again and stopped again. I think it heated up when it stopped and tries to start back once it cools down.Can someone please tell mme what is wrong and how can I get it fixed.
  • 185 Answers
Check the motor coupler
Posted on Mar 26, 2008
SOURCE:
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
Noise in the spin mode on a Amana LWA50AW top load washer
Based on your description, it sounds as if your outer spin bearing is faulty. See link below for an illustration of the bearing. Special tools are required to replace this item.
Illustration provided by; www.repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-ALW480DA-%3d%3di549695&PartID=549695
Aug 07, 2009 | Amana ALW480DA Top Load Washer
How do you diagnose a bad washer pump vs a cloged line?
Amana ALW480DAW seems to be not completely draining. When I start a new load water in basket becomes dingy and smells. Washer smells when it has not been used for a couple of days. We have checked the outflow and inflow drain tubes found no problems. It seems to spin and agitate normally, it drains to a point and leaves water in it, not visible in the basket. When we blow on the outflow tube when it is done draining there is still water present, we can hear it bubble.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kicks out?
the smaller belt is causing the tub to spin too quickly. the shorter belt is causing the motor to overheat and causing the thermal overload protector to shut dowqn the motor. when the motor cools it starts up again. replace the belt with te correct size and that will solve your problems
Oct 11, 2007 | Amana NAV2335A Top Load Washer
Slow leak in our HE 3T Washer?
khorak, I've seen this on this model a bunch of times. The inlet valve is weeping water. You need to change it out. The top has 3 screws in the back and it will slide off toward the back. The valve sits on the left side, right up on top. Easy job, part number is 8181694. Catriver
Jun 23, 2007 | Kenmore Elite 45986 Front Load Washer
Can't get washer to finish spin cycle
I'm not familiar with this washer, but if there is water in the drum when it comes to the spin cycle chances are that it won't spin. The likely cause of water left in the drum would be that it is not emptying fast enough, so you might check the pump for a blockage, or if there is a filter check that for some obstruction like fluff, coins, or small items of clothing which can sometimes get drawn through from the drum. Tom.
Mar 09, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Amana NAV5805A Top Load Washer Logo
310 people viewed this question
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
