Freezers Logo
Posted on May 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have just purchased (2nd hand)a Bosch Economic Upright Freezer but it did not come with user manual. Upon opening the door I can see a set of lights which suggest that I am able to adjust the coldness of the appliance. I have a range from -16 to -32 together with a button marked "super" and an on/off button. At what temperature should I keep the frezzer for normal domestic use and how do I adjust the setting please? Many thanks in anticipation of your reply **** Mitham
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on May 07, 2010
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
579618
Points
4327
Google manuals on line
HI I JUST PURCHASED A 2ND HAND WESTINGHOUSE UPRIGHT FREEZER FJ383T. WAS RUNNING FINE WHEN I PICKED IT UP, GOT IT HOME AND TURNED IT ON THE NEXT DAY,AND THE ALARM LIGHT IS ON. ANY SUGGESTIONS. CHEERS
did you leave it to stand with no power on for an hour. ? check the door seals are clean and the door close properly. wipe them down on the magnetic seals around the doors. plugging in the unit before it settles can leave air in system from being moved around. this makes the system work harder and gets to hot. in the line.
Jan 02, 2018 • Freezers
I have bought a Ocean Upright Freezer second hand and it came without a user manual, just wondering what is the best setting for it?
See if you can download a manual for it and get the recommended setting. Or just experiment with the knob and wait for a day to take the temp and adjust it accordingly.
Jun 19, 2017 • Freezers
Managemylife com sears
You have a Kenmore upright, which you set on ZERO? WHY?
Every time you open the door all of the cold air falls out and it has to start over in the cool down cycle, the fan stops to NOT push all of the COLD out while the door is open - you should consult a professional. Not for the freezer, for your ability to understand.
Need a user manual for a thermatech kbf2340 upright freezer
I would like manual for theramatech temperate upright freezer controls are on the front on the right hand side has pro & mute on one button arrow up with aux
other button has set def with arrow
Feb 14, 2014 • Freezers
Things don't freeze on the top shelf right hand side of the door. Also have small amount of water that drips after freezer is opened. This is a manual defrost freezer 20 cu foot freezer
I would suspect the door seal is not making contact or has some defect in it. And that defect is probably in the top right corner of the door. If you have a thermomiter, wait until the compressor kicks in and then slowly run it around the door seal. There should be some area that is colder than the rest. If I am right, then you will need to replace the seal.
1helpful
I purchased a Sears upright freezer in 2007. We keep it in our kitchen. Recently I noticed brown spots on the door of the freezer. Upon looking closer, I discovered it's rust! What can I do? The...
dear sir /madam
i think you should use anti rust spray WD-40 on your door after make clean it with sand paper . after clean make same colour there coz your freezer is working good so i think no need to buy new.
hope answer the question
thank you
please vote!
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
