F13 is showing on my hotpoint aqgmd 129 washer dryer when drying. still washes but says machine is blocked. any ideas? ty,
  • 108 Answers
SOURCE: hotpoint wd64 washer dryer
mits86 , you are correct - it could be the belt.
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
- If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
Please dont forget to rate me as fixya.
Posted on Mar 26, 2008
SOURCE: I have a BWD 129
Filter blocked, disconnect hose from under sink connection and drain into bucket. Hotpoint does not want you to change filter, contact Service Engineer.
Posted on May 06, 2008
SOURCE: Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Posted on Dec 22, 2008
SOURCE: Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Posted on Jul 23, 2009
SOURCE: Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Posted on Apr 01, 2010
Testimonial: "Yes, this was the correct solution for this particular model of W/M. Many thanks!"
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Please can you advise what the error code f13 means on hotpoint wdd960 washing machine? I have notived that it often happens on the drying cycle of the 60 minute quick wash dry programme. Is it safe to...
its the dryer fan thermostat, faulty. the unit will turn off if it does not read the thermostat and that's why you have a code. I would say its safe to use but would have the thermostat replaced. here is a video on how to replace the heater. https://www.espares.co.uk/advice/careandmaintenance/how-to-fix-an-f13-error-on-a-washer-dryer-hotpoint-indesit and these are the sensors. https://www.partmaster.co.uk/washing-machine/wdd-960-k-uk-f069442/thermostat/catalogue.pl?shop=hotpoint&path=52516&model_ref=967828&refine=thermostat, hope this helps.
Feb 27, 2018 | Washing Machines
PROBLEM WITH HOTPOINT WASHER DRYER - MODEL BWD 129-ON DRY CYCLE CLOTHES COME OUT STEAMING AND WET. PLEASE ADVISE
If the clothes are coming out hot and steaming, then the water from the clothes is not condensing, it could be a blocked condenser, which will have to be removed and unblocked and cleaned.
The other possibility is that there is no cold water coming in on the drying cycle, this can also have the same effect.
Hope this helps.
Dec 03, 2009 | Hotpoint Washing Machines
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Dryer problrm
The sympoms are typical of a couple of reasons.
  1. Blocked condenser.
  2. faulty cold inlet valve, not letting water in to condense steam back to water.
When it is on the drying cycle, see if you can see water pumping out of the drain at. a slow rate.
If you can see no water at all coming from outlet hose, then chances are it is a faulty valve, and you will have replace same.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Fault f13
Hi. F13 indicates dryer fan motor or thermistor problem
If you can't hear the fan motor running on the dry cycle then it is probably faulty.
Hope this helps.
Please feedback.
Thanks
Nov 13, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Washer Dryer WD865 - Dryer Problems
thermister blown or thermal fuse which is a black plug in the top of the dryer box or yellow sleeved wire, if it was noisy maybe the fan has come loose from it's motor. you will need to remove the dryer box on top of the drum to see if the fan is binding. you can push it back to where its not binding and tighten the nut-ANTICLOCKWISE, LEFT HAND THREAD.
usually the machine runs through a check before starting a cycle and will see an f13 and not start even a wash., so you will need to replace the blown parts.
Oct 25, 2008 | Hotpoint Ultima WF865 Front Load Washer
I have a BWD 129 Hotpoint intagrated washer dryer and lights 1 2 and 4 are flashing what does this mean and do I need a new machine it will not do a drying cycle?
Apr 03, 2008 | Washing Machines
Washing Machines Logo
363 people viewed this question
Top Washing Machines Experts
