Question about Belkin (F5D7230-4) Router (587009)
Broadband modem linked to computer thru usb.
My broadband modem is linked to computer thru usb port. I have tried to link thru ethernet, but not working. What should I do?
  • 68 Answers
Please check the the LAN card is working or not
you can check by typing IPCONFIG in command promp and after that type ping 127.0.0.1
If you are getting reply then the LAN card is working.
Check the ethernet cable after that
Posted on May 04, 2010
I'm trying to hookup a usb modem broadband to a router for a desktop and laptop
This wireless router does not have any USB connection on it. Types of connection available on this router are wireless and Ethernet. You can check on the modem if there is an Ethernet port on it.
If your modem has an Ethernet port, I recommend that you test the Ethernet connection using one of your computers. We want to make sure that the Ethernet connection on the modem is enabled. If not, you may need to contact your ISP or the modem manufacturer to make sure that the Ethernet will work before you install the router.
If your modem does not have have an Ethernet port on it. This is not the router that will do the work for you. And I personally does not seen any router yet with the USB port for the modem.
Feb 10, 2010 | Linksys Wireless-G Broadband Router
Trying to hook up a dlink router using cricket broadband wireless modem. need help?!?!?
Cable-modem (or DSL-modem) --> WAN port on CRICKET
and you _have_ a wireless network, without using the D-Link.
If you really want to get yourself confused:
LAN port on Cricket <--- Ethernet "cross-over" cable ---> WAN port on D-Link router.
Jan 28, 2010 | D-Link DIR-615 Wireless Router
How to connect the lancable and what is the
color code? just go get a standard ethernet cable (straight thru, patch cable) and plug it into the ethernet port on your computer and the modem.
Dec 07, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Connect two computers to D-Link ADSL Modem (DSL-502T)
There are many USB to ethernet adapters available, for example - Belkin USB to Ethernet Adapter with 2m Patch Cable from Amazon. Your laptop may only be USB version 1.0 so it would be best to make sur the adapter supports USB 1.0 and 2.0.
Nov 01, 2009 | Computers & Internet
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I Have a D-link DI-524 wireless router and verizon Broadband modem w/USB conection the G router only has ethernet connections .How can I make this Combo work?
If your Broadband modem is only with w/USB connection you have to change modem/router, you won't connect it with usb to di-524.
Jul 05, 2009 | D-Link AirPlus DI-524 Wireless Router
Broadband
purchase and install a broadband router. connect both computers to the router. make sure to follow the particular routers setup instructions fully
Mar 22, 2009 | D-Link 4-Port Ethernet Broadband Router...
Automatic installation failure
unless you were switching from DSL to cable Broadband, there usually wouldnt be much reason to rerun the software just because you got a new computer. when you ran the software the first time on the other computer, it was the router you were setting up, not the computer.
if the new computer is not getting internet when hooked to the router, try this.
1.turn off computer and unplug electricity from router and cable modem.
2. connect all ethernet cable to the right location. ethernet from modem to router goes in the non-numbered port, ethernet from your computer to router goes in numbered port.
3. plug in cable modem electricity first, wait for all its lights to come on like normal.(this part is important). the ethernet light on the modem (it might be labeled ethernet, link, pc link, or something similar) will not be lit, this is normal until you get to the next step
4. plug in the router electricity, give the router 2-3 minutes to get connected to the modem.
5. start up the computer, wait for everything to fully load and check internet again.
hope this helps.
Mar 21, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
How do i connect up my router
To physically install the router
Step 1: Connect the power adapter Connect the power adapter to the router and plug it into an electrical outlet not controlled by a wall switch.
Step 2: Connect the router to the computer Disconnect the ethernet cable that is connecting the broadband modem to the network adapter in the computer. Connect the ethernet adapter in the computer to one of the LAN ports on the router.
Step 3: Connect the router to the modem Connect the ethernet port on your broadband modem to the WAN port on the router.
Step 4: Check link lights and connections
Check the front of the router to make sure the Power, WAN and LAN1 lights are on.
Jun 29, 2008 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
