Question about Air Tools & Compressors
Ac compressor not coming on 2001 cadillac deville
Just added freon and ac still not working
  • 374 Answers
there are several test to be done and analysis on trouble shooting ac performance.if the ac run smoothly but insufficient cooling effect was taken after recharching factors can be obtain in poor performance of compressor,clogging of tubes mostly on capillary tube and expantion valve.this main factor
contribute on ac in sufficient cooling.compressor performance can check the on the discharge valve by mounting a hi side pressure gauge and check the lost compression effeciency.while the compressor is running if it can discharge a pressure higher than the operating pressure w/o losses on psg. you have good
compressor performance.but if can not maintain a operating pressure you replace compressor.if the compressor is good check the capillary tubing by purging and cleaning the system,obstruction can't expand the freon inside your evaporator,have a nice day don't forget to fix my rate.also recharge exact amount freon on the system don't exceed.poor refrigeration was the result,no cycle will occured.
Posted on May 08, 2010
If 2001 cadillac deville is low in freon how will ac blow
Not cold,but fan will work the same but the windows will come down so fast.
Jun 02, 2013 | 2001 Cadillac DeVille
93 cadillac deville. ac blowing hot. only one pound of freon but compressor wont kick on to allow for charging. where is the relay for the compressor, or what am i missing here? thanks
There is a sensor inline on one of the hoses or on the ac evaporator that should have 2 wires. Unplug the sensor and take a short piece of wire and make a U shape with it and plug it into both ends to complete the circuit on the wired side not the sensor. This will trick the AC pump to turn on. You will also be adding the can or two of freon. If the pump does not turn on after tricking it there may be a problem with the pump or a problem with wiring or the temp control.
Jun 08, 2011 | 1993 Cadillac DeVille
Why my ac in my cadillac deville 1996 blows hot air?
If your low on freon then the A/C wont come on? for a 1996 you will need to get it serviced if you havent its normal to loose 10% freon a year,
May 06, 2011 | 1996 Cadillac DeVille
1986 Cadillac sedan deville is my first car. the A/C doesn't work. Air blows out of the vents but it is not cold. I checked the fuse, that is fine. I don't really know what I'm doing, so any...
I would try charging the ac system with some freon,and see if that is the problem,the ac compressor will not come on unless the ac has freon,and enough to turn it on,disconnect the negative battery terminal for 25 seconds before doing this to reset the ac system.
Aug 17, 2010 | 1986 Cadillac DeVille
The ac on my cadillac automatically switches to economy instead of auto and will not come on
your ac compressor is not coming on, could be low freon, or bad compressor,
Jun 05, 2010 | 1996 Cadillac DeVille
2001 cadillac deville ac compressor not coming on
Try adding some refrigerant as it won't come on as a safety feature if it is too low in pressure.
Otherwise, it may be an electrical break in the clutch wires, or a bad fuse.
If it is like my 1990 Cadillac Deville, the a/c compressor will not come on at all until the battery is disconnected for several minutes and reconnected, and then charged with at least .5 lbs. of refrigerant.
May 26, 2010 | 1996 Cadillac DeVille
2001 Cadillac Deville AC Off message, will not blow cold air
does the ac clutch kick on? does the car have freeon? u will have to take it to autozone and let them use a scan tool
Mar 15, 2010 | 2001 Cadillac DeVille
How do i get the compressor to run to ad freon
If you're getting a AC error light, but you're sure the compressor works, you need to reset the compressor. Disconnect the battery for 20min (keep in mind, this will reset everything). After 20min, reconnect the battery. When you turn on the AC, the light shouild go out (AC error light). Be ready to add freon right away or the compressor will shut down again. Post back if you need instructions on adding refrigerant. Best of luck.
Greg
Jul 15, 2009 | 1996 Cadillac DeVille
My ac does not blow cold in my 97 cadillac deville but it does blow just not cold and its n ot the fuse what can i do?
You probably have leaked out your freon after so much time. Try adding some more Freon if it doesnt stay charged you may have bigger issues.
Jul 08, 2009 | 1997 Cadillac DeVille
1998 cadillac deville reads service ac system
Hi,check if the compressor clutch is engaging,if not check the conection at the compressor if ok check,fuse ,or relay ,if those are fine and the commpressor is engaging,check freon presure ,may be too high or low, if this is the case ,correct the problem and disconect the negative cable from the battery for a minute to reprogram the sistem..C1
Jan 04, 2009 | 1998 Cadillac DeVille
Air Tools & Compressors Logo
168 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
