Question about Kitchen Ranges
I have a Hotpoint Cooker 6109, there is one loose wire, thick white one and I don't know where to re-attach it to. The cooker has never been used so this should be the only problem with it, it causes the oven not to work. Please help.
  • 2 more comments
  • janicecs Mar 26, 2008
    All that I find are instruction books, not service manuals. Its just one thick white wire that has come unattached at the top end that could re-attach to a number of places. Any advice would be much appreciated
    Doing the best guess blew the fuses unfortunately, that why i am asking for a better clue please
    that's not so helpful, i don't have a sixthe sense when it comes to electrics, i am afraid of blowing the whole thing!
  • janicecs Mar 27, 2008
    The wire is from the oven and it's the one with heatproof insulation. It is loose in the switch area there are several terminals on the oven switch. They all trip the overlaod.
    Genius:
  • 1,665 Answers
You need a service manual
Posted on Mar 26, 2008
    Genius:
  • 1,913 Answers
Hi
open your cooker and check that white option and attach it.
  • 1 more comment
  • kishor khatri
    kishor khatri Mar 26, 2008
    hi
    check your cable and gueesing which connection nearly to cable and comfort.
  • kishor khatri
    janicessssssssss
    all girl have sixth sense if u r lady
    then u have done
  • kishor khatri
    kishor khatri Mar 27, 2008
    OK
    DEAR I M NOT COOCKER ENGINEER I M IT ENGINEER
    BUT I WANT TO REPAIR YOUR COOKER.
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
Water spewing everywhere pressure cooker
Happen to me cooking porridge when the mixture within the pressure cooker is too thick such that not enough steam is produced at ounce to get the cooker to seal itself. Add water if possible.
Jul 29, 2012 | Fagor 8 quart Duo Pressure Cooker
I have an aroma rice cooker model #arc-150sb c1 displays on cooker and no buttons work, can't eat broke collage student. Need to fix asap.
Thermal Fuse Problem.
If there is no heat/power, check the continuity o the thermal fuse( white resistor type in the internal wiring connections ). Unscrew and open the cooker at the bottom side.
Replace it w/ similar temp. value.
DON'T SOLDER IT!
Hope that helps you out!
Sep 21, 2011 | Kitchen Appliances - Others
Hi, I have a hotpoint cooker hood and the lights keep fading out then flashing on again.
Sounds like loose/burned wiring at the plug or spur unit .Check mains feed
Feb 22, 2011 | Hotpoint Microwave Ovens
Zanussi cooker
thanks but solved the problem.The white wire was loose in the socket on wall.
Oct 14, 2008 | Zanussi Kitchen Ranges
We have just purchased a year old, 2nd hand hotpoint electric cooker C367EKH and are trying to wire it up but having no success, please can u help?
The wiring box is on th rear of the cooker & is self explanitory...
What exactly are you having a problem with?
Jun 21, 2008 | Hotpoint Kitchen Ranges
Hotpoint EW81 Dual Oven Cooker
Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
New switch is a Diamond H - 48ER101C1P.
Numbers on switch are S1,P2,2,P1,4,S2
At the moment I have no cooker - help.
Sep 08, 2007 | Ovens
Kitchen Ranges Logo
95 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
