Question about LG DLE5977 Electric Dryer
My dryer is heating up
My dryer tumbles but no heat.
  • 721 Answers
Needs a new heating element.
Posted on May 04, 2010
Hi. My tdvcw bush tumble dryer turns but won't heat up. There's no reset button. Also the temperature light is flashing
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
If your tumble dryer isn't heating up, it's likely that the heater may .... helllo, i have a bosch dryer it works ...
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
For all your tumble dryer spare parts go to http://bit.ly/1LJTuT6 In this video, Rory shows us how to change the ...
Jan 25, 2016 | Dryers
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
? 2:33
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Nov 28, 2015 | Candy Dryers
Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Aug 13, 2010 | Whirlpool GEW9250 Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
The tumble dryer is working but not heating??? cleaned all filters and water tank. any ideas???
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. In your case it is better that y ou call in an engineer to test it. Also overloading and blocked filters can cause the thermostat to cut out and they can also go with simple wear and tear. Check your service manual for spare parts etc
Jul 19, 2009 | Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
LG DLE5977 Electric Dryer Logo
236 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
