Question about Rockford Fosgate Punch P4004 Car Audio Amplifier
My Fosgate P4004 is 3.5 years old and just started blowing fuses. Do you think the amp is shot or might there be something else going on and how do I tell?
  • 83 Answers
SOURCE: fuse blowing
send it off for repair
Posted on Jul 06, 2007
  • 631 Answers
SOURCE: rockford amp cut out
Disconnect all speaker wires from the speaker terminals of the amp and disconnect the RCAs. Replace the 30 amp fuse with a 15 amp fuse. If you turn it on and it blows the fuse, it's likely that it has shorted output transistors. If that's the case, you need to have the amp repaired.
Posted on Dec 22, 2007
  • 91 Answers
SOURCE: im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Posted on May 06, 2009
  • 3 Answers
SOURCE: rockford fosgate 450.4. 1st protect mode, now blows fuses...
smell it !
Posted on Oct 13, 2009
  • 12 Answers
SOURCE: Rockford Fosgate Punch P325.1 Amp keeps blowing
well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
Posted on Mar 18, 2010
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
Mar 18, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
I have a rockford fosgate 550 that the fuse blows
Short inside one of the transistors. This requires very good soldring skills and electrical know-how, and some thermal paste to go between the heat-sink and the transistor. Unfortunatly this is not a cheap repair, probably cost around 100 dollars.
Cheers,
Kevin
Feb 09, 2010 | Rockford Fosgate Punch P550.2 2-Channel...
Amp was hooked up without fuse from battery to amp
Another failure must have occured, as the fuse would have blown, possibly limiting the damage, however something did fail to start the problem.
Nobody can give you an honest estimate without analyzing the damage.
A wild guess would be one-half the cost of the unit.
Sep 10, 2009 | Rockford Fosgate 100a2 Car Audio Amplifier
Im having trouble i keep blowing fuses on my amp?
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Did it only blow the fuse AFTER you applied remote voltage?
If you're going to try it again, do so with nothing larger than a 20 amp fuse.
Nov 12, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
800.2
Well when you blow a sub it can definantely short your output fets in the amp.
Nov 09, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Rockford amp cut out
Dec 22, 2007 | Rockford Fosgate p-450.4 Car Audio...
Cold weather blown fuse
You might want to try better quality fuses, or allow the amp to warm up a bit before you start bumping down the street make old ladies angry.
Jun 01, 2007 | Rockford Fosgate Punch 700S Car Audio...
Rockford Fosgate Punch P4004 Car Audio Amplifier Logo
115 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
