Question about Ricoh 3310LE Plain Paper Laser Fax
Date and time stamp
Is there a way of making the fax machine print the date and time it receives the fax, and the number of pages sent on the fax it receives?
  • 201 Answers
Here's the instructions for the date/time stamp.... I'll check on no. of pages and post that too.
Press the 'User Tools' key.
Use the right/left arrows until '2. Fax Features' is displayed.
Press the 'OK' key.
Press right/left until '4. Key Op. Tools' is displayed
Press 'OK'
Press '2222'
Press 'OK'
Press right/left until '7. User Parameters' is displayed
Press 'OK'
'1. Change' should be displayed - Press 'OK'
Now 'Refer Op. Manual: Switch 00 :xxxx xxxx' should be displayed; use the right/left arrow until 'Switch 02 :xxxx xxxx' is displayed (xxxx being a bunch of 1's and 0's).
When 'Switch 02' is displayed, the third digit from the RIGHT should be a 0. Press the '2' key, and that digit should change to a 1.
Press the 'OK'' key.
You should be back at the 'User Parameters' menu - just press the 'User Tools' key to return to the standby display.
Presto, try it out!
Please rate if this helps :)
Posted on Mar 05, 2009
How do I print the fax confirmation page on the x4270? Are the instructions printed anywhere? How to set the time?
here's the solution to enabling fax confirmation: press the fax button on the printer front panel,the press option 16 or until advanced fax appears.(you can also press the right arrow to get to that option). press select push options twice.fax confirmation menu will come on the front panel display.push the right arrow button. The following options are displayed: Off - Select this option to receive no confirmation. Print for all - Select this option to receive confirmation whenever a fax has been sent, whether successfully or not. Print for errors - Select this option to receive confirmation (an error page) only when a fax has not been sent/received successfully.
***************************** here's the solution for setting time on printer display on the printer control panel,push fax push options until EDIT DATE/TIME: appears on the printer display to change the date: - press select - use the keypad buttons to enter the date. Note: If you make an error entering the date, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction. - press select
To change the time: Press the right arrow once, and then press Select. Press 1 for 12-hour time or 2 for 24-hour time. Use the keypad buttons to enter the time you want your All-In-One to display. Note: If you make an error entering the time, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
Press Select. If you are using 12-hour time, press 1 for AM or 2 for PM. Note: If the time is entered incorrectly, the time shown will be the default.
************************************************** i will also put in the link for the manual for additional assistance: http://www.lexmark.com/publications/pdfs/4200/eng/frameset.html
Jun 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
I would like to print a transmission report for a document that I just sent.
Hi
You can print a log of faxes that have been received and sent by the device. Each
entry in the log contains the following information:
• Transmission date and time
• Type (whether received or sent)
• Fax number
• Duration
• Number of pages
• Result (status) of transmission
To print the fax log from the device control panel please follow the directions below
1. Press Setup.
2. Press right arrow to select Print Report, and then press OK.
3. Press right arrow to select Fax Log, and then press OK.
4. Press OK again to print the log
All the best!!
Regards
Nov 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
Is there a way for me to leave a date/time stamp when sending a fax on my intellifax 1940CN?
if you enable send report you can get an a4 page with time and date confirming that the fax has been sent, but when set up it will print for every fax. the other option is to have it print on error only and you can manually print report of sent recieved items( all date and time stamped) with the number sent to as a list.
Aug 10, 2009 | Brother IntelliFAX 5750e Laser Fax
How do I change the date stamp that prints when I send a fax
Ring the person you sent the fax to and ask them to white-out the date printed and fill in the required date.
Alternatively, you could read the Operating Instructions (http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL501%20Plain-Paper%20Laser%20Multifunction.pdf) and check page 17.
Jun 07, 2009 | Panasonic KX-FL501 Plain Paper Laser Fax
Date received at top of page.
you cant you are going to have to go get a time/date stamp machine and put each one through it
sorry i couldn't of more assitance but your machine does not allow for that feature
May 04, 2009 | HP LaserJet 3050 All-In-One Printer
Time date stamp on fax machine
The time it was sent, if they have the time set correctly on the sending fax machine
Mar 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Print out confirmation with image on page
press
function
7
monitor key slowly 4 times
set
look on the sheet for confirmation + image parameter
set with above procedure but use number 74
set
Feb 04, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Verification stamp
there is no function to print it on the fax you sent but you can have a come journal.
press the following.
function-7-4-start-1-2-start-2"should say always" start stop then this will give you what you want
Jan 20, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
Ricoh 3310LE Plain Paper Laser Fax Logo
309 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
