Question about Bunn NHB Coffee Maker
Slow slow how do i clean this out the de-liming tool for the other bunns wont fit?
  • 189 Answers
Please call Customer Service and the correct deliming tool can be sent to you.
Posted on May 19, 2010
Coffee machine every slow
Water discharge tube from heated tank is likely caked with mineral deposits. Bunn makes a de-liming tool for just such a problem.
Google "bunn deliming tool", or buy it on Amazon.
Bunn Deliming Cleaning Spring 01193 0000
Jul 25, 2014 | Bunn 10 Cup Home Coffee Brewer
Bunn Coffee Maker VPR - should we put vinegar in the reservoir and run it though - of should we just put a little vinegar in with some water? We ordered a de-liming spring tool and we will use it when we...
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Aug 16, 2011 | Bunn VPR Coffee Maker
My bunn vlpf coffee maker the water tank is overheating to the point of steam is spewing fro the air release tube... I'm thinking thermostat ?
You are correct.Also check the tank for lime.By unplugging and removing top of machine (2) screws and remove fill basin.You can then remove your t-stat probe to check.If it is lime up you can crack off the lime and reinstall it in the tank.If limed up I would suggest de-liming.T-stat part# 4314.0001.
Jan 29, 2011 | Bunn VLPF Coffee Maker
How do i adjust the water flow from the hot water dispenser? I need it to come out faster.
If your talking about the hot water faucet the flow rate can't be adjusted.There may be a blockage from lime at the tank fitting.You will need to clean fitting of lime.
Nov 06, 2010 | Bunn Dual TF DBC Coffee Maker
Lime in coffee pot
We recommend cleaning your machine with white vinegar for 2 hours and then using the metal deliming tool under where the sprayhead is located. IThen flush it out with 8-10 decanters of water. If this doesn't fix your problem, please call customer service at 800-352-2866 with the model and date code.
Jul 20, 2010 | Bunn 10 Cup Home Coffee Brewer
Bunn perks coffee very slow?
This is generally an indication of a lime build-up in the water tubing. If you take off the sprayhead and insert the metal deliming tool into the water tubing all the way leaving out about 1-2 inches and twist it about 5-6 times, this should remove the lime deposits from the water tubing. Then flush out the machine with 2-3 decanters of water. If this doesn't fix the problem, then call customer service with the model and date code for further assistance.
Aug 01, 2009 | Bunn GR10 Coffee Maker
HAVE LOST MANUAL. HOW DO I CLEAN IT
You will need the de-liming tool to proceed. Run a pot of white distilled viniger thouth the coffe maker. Viniger is a excellent cleaner & will not hurt any internal parts.
Jul 28, 2009 | Bunn 10 Cup Home Coffee Brewer
Taste
Check your water supply lines if your unit is hooked directly into a water supply. Your unit either has to be cleaned (de-limed) or your water source is bad. You could try using filtered water, but if you have residue inside the unit it must be flushed with a professional delimer if white vinegar doesn't do the trick.
Feb 09, 2008 | Bunn BT10B Coffee Maker
My bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn NHB Coffee Maker Logo
124 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
