Question about Lexmark X4975 Wireless Color Multifunction All-In-One Inkjet Printer
Lexmark X4975 wireless printer will not wirelessly connect
I followed the sugested answer #2
I went to settings->Network setup (no network/wireless setup). There is no option to reset the network adaptor. (I reset the factory settings). Still no orage light on the WI FI indicator. But the printer recognises the network name and has a strong signal.
4 Suggested Answers
SOURCE: Lexmar 4875 Flatbed Wireless printer not connecting to the networ
I know you posted this in May, so have probably given up and bought a new printer by now, but I thought it worth mentioning that I had the same problem exactly (though without the same number of iphones and laptops!).
Buried away in some documentation on the driver CD, is the fact that the X4875 can't communicate with a secure wireless network that uses a TKIP algorithm - it can only handle AES. My router used TKIP out of the box, and I never thought to change is, especially as it's stronger than AES. However, changing it to AES solved the problem.
By the way, if you're using Vista, you may find that you have to run the install package in Windows XP compatibility mode, and then when the install is complete, manually change every .exe under c:\program files\lexmark\.. to run in XP compatibilty mode too. Works for me (Vista Business), but didn't work wirelessly at all before. Good luck,
Chris J.
Posted on Jul 13, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: have lexmark x3550 printer. but can't get wi fi
    Reset the Network Adapter of the printer by pressing the Settings button on the Operator Panel on the printer> Network Setup> Wireless Setup> Reset Network Adapter to Defaults> Yes. Reinstall/reconfigure the printer for wireless connection. Make sure you are using the correct wireless network information and that the computer belongs to that network. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    Posted on Apr 26, 2010
    Printtech
    • 1087 Answers
    SOURCE: my lexmark x4975 will connect by USB but will not
    With the wifi light off, it's not possible to make wireless connection go through. The wifi light should light up orange before configuring it to work wireless. Try this, press Settings(wrench icon) > Network/Wireless Setup, then Ok > Reset Network Adapter, then Ok. Wait for the wifi light to show up orange in few seconds. If no go, unplug the power supply(the black box behind the printer where the power cord is attached). Wait for 10-15 seconds before plugging it back in the printer. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    Posted on May 03, 2010
    Set up wireless network
    You can run the Wireless Setup to connect your printer to your network. To access that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home > Settings tab > Wireless Setup Utility.
    Nov 20, 2012 | Lexmark Intuition S505 - multifunction ...
    No ip address and there is no communication
    You'll have to connect your printer to your network to get a valid IP address. If you've already tried that, please unplug the power of your printer for about 30 seconds then plug it back in.
    Once your printer is back on, connect the USB cable and run the wireless setup. You can access that through Lexmark Printer Home. To access that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home > Settings tab > Wireless Setup Utility > Follow the prompts.
    Make sure to type in the correct credentials for your network.
    Nov 19, 2012 | Lexmark Interpret S405 Wireless All-in-One...
    How to stop orange wi fi light from blinking
    The blinking WiFi light on your printer could indicate that it's trying to communicate with your wireless network or it's not connected to your wireless network anymore. A quick fix to this problem can be achieved by rebooting your system. Simply unplug and re-plug your printer and your wireless router into the power outlet and reboot your computer. Once everything turns back on, check the status of the WiFi light and try to print again to verify that the problem is fixed.
    You can also do the following steps to reset the printer wireless network adapter:1. From the printer operator panel, press the Setup button.2. Select Network Setup.3. Select Reset Network Adapter.4. Hit the OK button.
    The WiFi light will momentarily turn off and then on solid orange. You can then try to reconfigure the printer to connect to wireless network using the Lexmark Wireless Setup Utility application on your computer. Go to Start menu > Programs > Lexmark 4600 Series folder > Lexmark Wireless Setup Utility. Simply follow the instructions on your computer screen.
    However, if you wish to have it connected directly to your computer. Simply connect the printer with the USB cable that came with it in the package.
    Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
    Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
    Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
    Here are some guidelines to identify and fix your wireless communication issue:
    • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
    • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
    • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
    If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
    Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
    Lexmark X4550 3 in 1. Although the wireless capacity has been loaded and activated it has ceased working and will not allow access.ie the flashing wireless connection light does not turn green just...
    Try to reset the printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Wireless Setup > Reset Network Adapter > press check to confirm.
    Re-launch the Lexmark Wireless Setup Utility to connect the printer to your network. If you have a firewall enabled, make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall. Also, place your printer where it receives excellent wireless signal quality and away from other electronic devices which can cause wireless interferences (e.g. cordless phones, microwave ovens, baby monitors, garage door openers, and other wireless electronics).
    Jun 27, 2011 | Lexmark X4550 InkJet Printer
    I want to connect to a new router but the orange wifi light is on and re installing software does nothing
    Try to reset the printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Adapter to Defaults. Once done, re-launch the Wireless Setup Utility in Lexmark Printer Home application. Follow the instructions on your computer screen. Make sure you enter the correct encryption code if your wireless network is secured. Also, allow full access to all Lexmark printer communication and processes in the program rules/permissions for your firewall.
    Jun 19, 2011 | Lexmark Interpret S405 Wireless All-in-One...
    How to turn on wifi
    Configuring the optional internal wireless print server
    If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
    1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
    wireless print server" in the "Setting up the printer" chapter.
    2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
    3 Click Wireless Setup.
    4 Click Start.
    5 Follow the instructions on the computer screen.
    6 Click Finish to complete the installation.
    Also here is the link to the setup guide and user manual
    click here
    configuring the wireless is in the setup guide
    Oct 18, 2010 | Lexmark X3550 All-In-One Printer
    How do i get the lexmark x4975 working wireless
    When setting up a Lexmark printer for wireless use, you must initially have the printer connected via USB. Once setup is completed, then you will have wireless access.
    Jun 07, 2010 | Lexmark X4975 3-in-1 Wireless Inkjet...
    My lexmark x4975 will connect by USB but will not connect by wireless. The help assistant asked if any lights were showing on the WI FI indicator - none are lit. How can I make wireless connection?
    using your pc/laptop you will have to create a new connection an search for the printer when this has been done, make sure the printers wireless is enabled before attempting to create a new connection
    May 03, 2010 | Lexmark X4975 Wireless Color Multifunction...
    Lexmark X4975 Wireless Color Multifunction All-In-One Inkjet Printer Logo
    339 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
