Question about Canon imageRUNNER C3220 Color Copier
I am trying to scan off of a canon 3220 bring it to photoshop and save it as a pdf for email
  • 2,069 Answers
You could download this pdf printer, scan your document and then use this software to convert it to pdf. install the software then go to the scanned document choose to print and choose printer " primo pdf" save and thats it
Posted on May 04, 2010
I can't select PDF for Format on the scan setting screen when scanning off Canon printer? There is no pdf option at all. What causing problem and what procedure should I follow to fix it?
I scan using M/S windows scan and fax app. I save the scan. Then I open the scan and print, selecting PDF printer on computer. From there I can open to read, send by email or print a hard copy from my printer.
May 03, 2017 | Canon Office Equipment & Supplies
I cannot email a scanned letter. I get the message: The operation failed. An object cannot be found. Microsoft Office Outlook. I have a new Del Computer and my existing Canon CanoScan 4400F. I can see...
As a quick fix, if I could see it on the screen, it should be possible to save it to the drive taking note of what name you saved it as. If you then drag and drop the file onto your opened email, it should attach to the email. If it doesn't, you should be able to drill down to where the file is on the drive via the paperclip symbol.
If the screen scan saves only as one page at a time, hopefully you can save each page as a PDF or convert what you do save to PDF. CutePDF or PrimoPdf may offer a driver for the conversion. There is a program called PDF binder (freeware) that does a great job of welding several pages into one file. Possibly the freeware program File Minimizer might reduce the file size. Yes, this is a time consuming work around but it gives you an option.
I doubtlessly have cracked up some other helpers with this convoluted method but at least you have my "bear claws and stone tools" method.
Jan 03, 2018 | Canon CanoScan 4400F Flatbed Scanner
I get "Send Error (SMTP)"
It took me a while to figure this out. Your 3220 must be connected to ethernet (I havent tried it with the 3220 connected directly to the computer). Also, this works with a free email with domain Godaddy account, so YMMV.
1. Open your web browser and navigate to the 3220's CentreWare IS. 2. Click on "Protocol/SMTP Server" 3. Check "Host Name" 4. Type smtpout.secureserver.net/80 for server/port 5. Check "SMTP requires authentication" 6. Enter your username/pw 7. Click "Save Changes"
If you are asked for a username/pw to save the settings, the 3220's default are admin/1111.
Now click on "E-mail/E-mail Setup" on the navigation. Make sure your default [From:] address is your sender email address (they must match). Click "Save Changes"
As a final recommendation, I strongly suggest that you create your address book (E-mal/Local Address Book on the navigation) to make it easier to send by email, otherwise you will have to manually enter email addresses using the 3220's keypad (very slow!). Create groups for sending scans to several emails without having to select each individual email from the 3220's panel (also slow!).
Hope this helps.
Dec 31, 2010 | Xerox WorkCentre 3220 All-In-One Laser...
I own canoscan Lide-25. I want to scan forms and fill in the blanks of the form from my computer then print for my use. How to do this? Am I to buy any splecial software other than OCR already provided.
I wouldn't use OCR, too difficult. I would save your scanned document as a jpeg and edit in Photoshop. From Photoshop thay can be printed or saved as a pdf file.
Mar 31, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
How to scan documents with canon mp160
i press scan button then asking me to select publisher or photoshop, after select both but nothing happen
Nov 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Save documents to a pdf file using Canon CanoScan 25
If you are using PhotoStudio, you should be able to save as a PDF file if you use the "Save as..." option in the File menu and select the appropriate file type. If you are just wanting a smaller file, I recommend using a program like XnView (http://xnview.com - it's free) to re-save the JPG file with a lesser quality setting. I have found that a quality setting from 60 to 75 compresses the file well without introducing too many compression artifacts.
You might also consider scanning at a lower DPI (try 150) and/or resizing your scan to make the image physically smaller.
Sep 25, 2009 | Canon CanoScan LiDE 60
Scan to pdf?
Hi
Try saving (Drag & Drop) the scanned document into a photoshop clip art file where it will get converted then save as a pdf, (XXX.pdf)
Paul Ireland
Perth, Western Australia
Nov 18, 2008 | Canon CanoScan N1240U Flatbed Scanner
Hi,I have got a Canon,smartbase MPC 400 printer/scanner. My question is: How can I scan a document straight to a PDF file,because it only gives me options for TIF,BMP and JPEG. I have downloaded a TIF to...
I'm using an MP780. Usually when I scan an image to jpeg I press START, CANON, SCANGEAR STARTER. This open a window to ScanGear MP. Since I use the Advance Tab I can set the DPI and whatever outputs. The DPI rsolution will determine the size of the file also. When it is finished scanning it goes to the next window which has Save As Type and Save Scanned Image to. Save As Type is where you can choose JPG or TIFF or BMP. Hope this helps.
Nov 13, 2008 | Canon Office Equipment & Supplies
Can't scan
Ok, you should be able to download a manual for your printer in adobe photoshop as a pdf and save it for your desktop, then put it on a cd or leave it on your desktop, or even print it from your desktop. SCanning should not be hard, place your document face down on the scan plate, close lid, if your pc has a scan button press it, or you could open your printers program on the desktop if it has one and choose scan from here. Once you have it scanned the right way you want it, ie you can enlarge or shrink etc to fit email save it to your documents folder or your desktop. Now open your email program and choose new email, add details as per who you are sending it to, and a subject line, now up the top it says insert... click on this and scroll to file. Now browse for your fax where you saved it, and attach it as a file attatchment. Now send it!
Aug 20, 2008 | Lexmark X6170 All-In-One InkJet Printer
Canon imageRUNNER C3220 Color Copier Logo
80 people viewed this question
old marine
old marine
