Question about Samsung 2243BWX Monitor
Backlight keeps dimming
About a week ago my 2243 BWX monitor started to get dimm then back to the correct brightness could it be my back light going bad?
  • 11,361 Answers
More likely to be the power supply or inverter circuits, testing the lamps will be harder without proper tools.
Please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 04, 2010
Why does acer monitor need color brightness adjusted every time I turn it on?
You need to save your settings after adjustment. It will revert back to standard setting if you don't save.
Sep 08, 2014 | Acer Computers & Internet
I have a lenovo t420 which has brightness/dim issue and can't correct it by unchecking the auto brightness
There should be a function key to adjust the brightness at the top of your keyboard my laptop is F2 or F3 so at the bottom of the keyboard is a key label FN The Function key looks like a sun with an arrow if you are lucky to have it labelled.
If this does not fix problem you may have a faulty laptop . There is a circuit called an inverter in your laptop that converts DC to a higher voltage AC to run the fluro backlight behind your laptop's LCD screen. If this inverter goes faulty you could experience the symptoms you are seeing. This would require a replacement of the inverter circuit board in your laptop by a repair service centre.
http://www.youtube.com/watch?v=fSCJzA0EBo0
http://www.youtube.com/watch?v=2Yi6GNFcP3w
http://ask.metafilter.com/92210/Backlight-or-Inverter-How-can-you-tell
Sep 05, 2014 | Lenovo ThinkPad T420 Notebook
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
Mylaptop screen keeps dimming then going bright
I suspect the backlight power of your monitor. Try to find out if the dimming is indepented of the angle of the monitor (e.g. just the time that the screen dimms out open or close SLOWLY the screen). If that is correct there is a problem (cut) in the internal cable that gives power for backlight at your screen. Reply by post.
Stelios.
Feb 23, 2010 | Computers & Internet
Gateway M-1631u screen keeps going to full backlight power
Connect an external monitor to your laptop. If it the image is ok on the external monitor and bad on the laptoop screen it means one of more of backlight/inverter/screen is defective. Have it repaired by a professional.
Oct 09, 2009 | Gateway M-1628 Notebook
Dim monitar with flickering screen
The problem can be caused by 1 of 2 things either your power supply is going out or the backlight bulbs are going out. The most likely cause is the power supply. If you are willing to do a little soldering you should be able to do the repair. If you go to our web site at: www.ccl-la.com/badcaps.htm We have a section on monitor repair. Look under the Samsung 930B it is the same as your monitor.
If you don't want to do it yourself we do offer a repair service, email me if you are in need of that.
I hope this helps.
Buddy
Aug 05, 2009 | Computers & Internet
Monitor is very dim until warmed up
maybe you got some capacitors dried on your monitor
Mar 06, 2009 | Norcent Technologies LM-760 17 in. Flat...
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Monitor stays dim
Chances are it's not the actual CFL back-light bulbs themselves, but the back-light inverter board. If it was the bulbs you would have not had the "warm up and it get bright" issue. The board IS replaceable, (as well as the bulbs) ViewSonic charges about $36.00 USD for the board when they have them in stock. (out of stock as of yesterday 11/14/2006) It should be covered under warranty if you got longer than one year. (I know the warranty was only one year on MY VA800 but I have seen longer offered since i got mine) Good Luck I hope this helps! El Duderino
Nov 11, 2006 | ViewSonic VA721 17" LCD Monitor
Backlight not working
Did you try to set the Backlight on in the control panel? (settings>system>brightness) The brightness is often automatically set to 0. If you did this already and it still doesn't work, probably try an email.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Samsung 2243BWX  Monitor Logo
262 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
