Question about Sony Playstation 3 (PS3) Console
Ip address failed
When trying to connect to the internet it says ip address failed
    Guru:
  • 229 Answers
  • In order to connect your console to the internet you will need the following:
  • Laptop with WiFi
  • Ethernet cables
  • USB cable
  • Video capture card
Below are the steps involved includind some additional information:
    File Sharing
  1. Step 1 Go to Settings in the PS3 menu and scroll down to Network Settings. Go to Internet Connectionip address failed - mag-glass_10x10.gif Settings and select your wireless router from the list of available connections. If the router has security, you must input your password. Internet Connection in the Network Settings list will say "Enabled" once you are connected.
  2. Step 2 Link the laptop and PS3 together through a router if you have one. Connect both the console and computer to the router with Ethernet cables. This is needed for a PS3 with 40 gigabytes of memory and that does not have WiFi.
  3. Step 3 Connect the devices directly with a USB cable. Use one of the USB-style ports the PS3 uses for its game controllers. This requires a USB cable with two thin connector plugs.
    Connecting to a Monitor
  4. Step 1 Purchase an external video capture card for your laptop. This device will connect to the computer through the USB port and will have both composite and S-video connections.
  5. Step 2 Connect the capture card to your laptop. Insert its included CD-ROM into your disc drive and install the software on it that allows the computer to recognize the card's drivers and includes a video viewing/editing application.
  6. Step 3 Attach the PS3 to the capture card using the console's RCA composite cable. Open the video application and turn the console on to view it in the program's screen.
  7. Step 4 Locate and click the application's "full screen" button to enlarge the game screen to your full monitor. THANKS. MIKE
Posted on May 04, 2010
Where can i find my gateway ping on windows 8?/
There may be a problem in your internet connection.You first read user manual whether it is possible to connect the blueray player with internet or not.If you cannot ping the ip address there may be a problem in it.Try to reset the modem and check ping for any ip address and website using the site Whoisxy.com .
Apr 02, 2013 | Lenovo Computers & Internet
Can't connect bluray to WBR1310
If the IP address is fixed in the BlueRay player, I would reboot the router or modem, which will reassign IP addresses. If one is in use, such as the Blue-Ray, whichever device is currently using it will get assigned a new IP address, assuming it too is not a fixed IP address.
Oct 27, 2017 | D-Link WBR1310 Wireless Router
This sucks
try to check the right ip address by connecting it first to your computer, check the ip address on your command prompt ( if you are using windows platform ) then type ipconfig /all
take note of your gateway, dns server, ip address ( so that your in the same network ) and the subnet mask.
Aug 18, 2009 | Sony Playstation 3 (PS3) Console
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
Ping www.yahoo.com - FAILED
try to check the ip address before accessing the internet.
if you not getting a valid ip address then try to reset you d link router.
Apr 13, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Failed ip address
your ip address should be activated by your isp
and then manually put it in the smart phone
Mar 04, 2009 | Microsoft Xbox 360 Console
Xbox 360 Connection to internet
the IP address will fail when it is set on manual, rather than automatic. Be sure, once you enter it, it is set to automatic
Jan 03, 2009 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
