Siemens computer During the process of creating backup system recovery discs my computer does not progress after DVD recovery 1 has been processed and ejected
    Guru:
  • 377 Answers
Hi dear
i think it's processing stop causing by internal failure, it's about your speed of dvd recording ...try to used a slower speed
and try to refresh your burning softwre
ok
Posted on Mar 27, 2008
Samsung recovery solution 5
Step 1:
Step 2:
Once Samsung Recovery Solution 5 loads, click Restore.This display is observed.
Step 3:
On the Restore > Complete Restore dialog, there is list of backups created using Complete Backup and the expected time needed to perform a restore with each backup. If no backups have been created then the Computer Initial Status backup is the only item listed. Click the backup you would like to use for this restore, and then click Next.
Important: Make sure you have power connected to the PC. If power is lost during a restore, you need to start the process again from the beginning.
Step 4:
Samsung Recovery Solution 5 prompts you to restart the computer to continue. Click OK to restart the computer.
Warning: If you have data on drive C that you do not want to lose, stop now and perform a Data Backup.
Step 5:
The computer restarts and Samsung Recovery Solution 5 prompts you to click Yes to Delete all data on drive C. Click yes to proceed.
Step 6:
A progress bar appears showing the current transfer speed, the amount of data copied, elapsed time and estimated total time to completion.
Step 7:
After the Complete Restore is complete, Samsung Recovery Solution 5 prompts you to restart your computer. Click OK to restart
Step 8:
After you restart your computer, the restore process is complete.
Note: You will need to perform an additional restart for Windows to apply its changes.
Mar 18, 2013 | Samsung Cell Phones
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
How do I make a recovery disk?
Which operating system ?
there are some you can download
If you computer crashes and your hard drive fails, you can lose a lot of data and spend a great deal of time trying to find all your discs and re installing all of your information.
It can be very difficult to find and re-install your operating system if you do not have the original CDs that came with your computer.
But if you create a recovery CD for your computer, the restore process can be much faster and quite easy.
Put the blank CD in your CD writer.
Click on the Windows Start button.
Click on the Control Panel option.
Click on Backup Your Computer from under the System Maintenance section option.
Click on the Backup Your Computer button on the Backup and Restore menu.
Select your CD drive from the drop-down list and press the Next button.
Click the Start Backup button to begin the backup process.
you might need to use dvd rw depending on the size of the backup
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you dont have a Windows installation disc, cant find your Windows installation disc, or cant access the recovery options provided by your computer manufacturer.
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click Next.
Note If you are using the Windows7 Install DVD then at the Install Now prompt (Do not pick the Install Now option) instead choose the Repair your computer option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that Windows found problems with your computers startup options.
Do you want to apply repairs and restart your computer ?
d) Click Repair and restart and reboot again to the Windows 7 System Repair environment.
e) Click Next at the keyboard selection prompt and when the System Recovery Options screen appears verify that the Use recovery tools that can help fix problems starting Windows is selected.
Note that on your Dual Boot system there now should be only one operating system listed.
Click the Next button.
f) Now from the menu list select the Command Prompt option.
g) At the DOS prompt type the following three commands
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an Eliment not found message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the Startup Repair option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages Windows cannot repair this computer automatically and Startup
Repair cannot repair this computer automatically.
These messages are the result of the radical changes made by removing the other drive.
Ignore the Send/Dont send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Dont send window.
Next click on the View advanced options for system recovery and support option and from the main menu once again click Startup Repair.
This time the repair process may only that a few seconds and when prompted Startup Repair could not detect a problem, click Finish and run the Startup Repair option one more time, click Finish, and then remove the System Repair DVD and click Restart.
Reboot the computer.
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
hope this helps
Oct 22, 2012 | Compaq Presario CQ70 Laptop AC Power...
Stery
1. Click Start -> Dell -> Dell Data Safe Local Backup
2. In the "Dell DataSafe Local Backup Basic Edition", click on "Backup". Then click "Create Recovery Media".
You have two options to create a Recovery Media - DVD Discs or USB Flash Drive. You can go with either of the options. You will need two 4.7GB DVD Discs or one 8 GB or larger USB Flash Drive accordingly. Choose the option and click "Next"
the application will now create the recovery media.wait for the process to complete.
so at anytime you desire to bring your Dell PC to factory state, you need to insert this media before booting and proceed with the restoring wizard.
Mar 02, 2011 | Computers & Internet
How do you restore it
All HP's and Compaqs (as far as I know) come pre-installed with a recovery partition. This replaces the functionality of a recovery CD or DVD, only without the hassle of losing or scratching a recovery CD or DVD. There is one drawback to this method; namely that if the hard drive (or more likely for you) solid state drive gets damaged or erased, you run the risk of also erasing this recovery partition. If this happens, you will need to go to HP's website to order a recovery USB key. Information for ordering a recovery key can be found here. Keep in mind you can only order one recovery key per system, so if you do have to take this route, be sure to create another using the information at the bottom of this post.
  • Press the Power button to start the PC, and then press the f11 key when the standard BIOS prompts are displayed on the black screen.
    NOTE: Pressing the f11 key during startup on a computer with an HP factory image will start the system recovery process even if the prompt is not displayed.
    • If the HP Recovery Manager can access the recovery partition on the hard drive, a prompt to backup the user files before beginning the recovery is displayed. Follow any on-screen instructions.
    • If the HP Recovery Manager cannot access the hard drive to fix any system errors, you will need to use the personalized recovery disc that you created to recover the hard drive to its original condition.
    • If you have not created the personalized recovery disc, or the discs are corrupted, you can order a replacement recovery disc from HP.
  • If prompted to use the Microsoft System Restore program, click No , and then click Next .
  • When prompted, if you want to backup your personal files and settings, select the Back up your files first (recommended) option, and then click Next . Follow the on-screen instructions.
  • When prompted to Recover without backing up your files , please STOP before clicking Next . WARNING: This is the final opportunity to change your mind about recovering the PC and deleting all the files and programs. Once you click Next , the restore process cannot be stopped.
  • If you are satisfied that you want to begin the recover process, click Next . The PC immediately begins formatting the hard drive and destroying all data.
  • The recovery process may take up to several hours and will return the PC to its original condition. Any custom settings, drivers, software programs and updates, and/or hardware updates are lost and must be reinstalled.
    Once this process is complete, you can create a recovery USB drive using the procedures outlined below:
    There are three options for recovering these mini notebook PCs to their original operating system image.
    • Option 1 - Use the Recovery Manager program on the recovery partition on PC. For Windows 7, turn on the power switch, press Esc key at boot followed by F11 key for the recovery menu. For XP, press F6 key for Roxio BackOnTrack utility.
    • Option 2 - Create a personal set of recovery media. For Windows 7 and XP use the HP Recovery Manager to create a recovery image on either a DVD or an 8 GB USB flash drive). For XP, use Roxio BackOn Track to create a recovery image.
    • Option 3 - One-time purchase of the Recovery USB recovery key.
    The USB Recovery key can be purchased from the HP web site. The USB key is larger than normal thumb drive. HP can ship only one USB recovery key per unit.
    Nov 25, 2010 | HP Mini 210-1030NR Netbook
    How do I format the laptop? There is function key that does it?
    Restore the pc to its original condition with HP Recovery Manager if computer can boot to the Windows desktop. Launch the Recovery manager
    Note:Before doing recovery try to back up the important data like pictures and documents.
    1.Click Start and enter Recovery in the search field. Select Recovery Manager from the list when it becomes available. Allow the action to continue, if prompted. The HP Recovery Manager opens.
    Alternately, click Start , All Programs , Recovery Manager , and then Recovery Manager . Allow the action to continue, if prompted. The HP Recovery Manager opens.
    1.Click Advanced options , System recovery , and then click Next . The PC will restart and reopen the recovery manager.
    Alternately, if Advanced options is disabled, click Next , and then System Recovery . The PC will restart.
    1.When the PC restarts, select the System recovery option and click Next .
    1.If prompted to use the Microsoft System Restore program, click No , and then click Next .
    1.When prompted, select the Back up your files first (recommended) option, and then click Next . Follow the on-screen instructions.
    1.When prompted to Recover without backing up your files , please STOP before clicking Next .
    1.If you are satisfied that you want to begin the recover process, click Next . The PC immediately begins formatting the hard drive and destroying all data.
    If the PC cannot launch into Windows, it may still be possible to use the HP Recovery Manager on the hard drive to restore the computer to its original operating condition. The Recovery Manager can be launched during the start up process by following the steps below.
    1. Press the Power button to start the PC, and then press the f11 key when the standard BIOS prompts are displayed on the black screen. NOTE: Pressing the f11 key during the startup on a computer with an HP factory image will start the system recovery process even if the prompt is not displayed.
    2. When the Recovery Manager starts, follow the instructions.
    Aug 14, 2010 | HP Pavilion dv2000t Notebook
    Recovery disc
    To create an Acer recovery Disk from the computer follow the below mentioned steps:
    Click Start Menu> All Programs> Acer erecovery management> Under it select the option to create Recovery Disk
    Aug 02, 2010 | Acer Aspire One PC Notebook
    How do I do a full recovery with the disc
    Turn your computer on.
    Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
    Change the boot device order to: CD-ROM, HDD in that order.
    Save changes and restart the computer.
    The Recovery Disk would boot up and a wizard will guide you through the recovery process.
    Follow the instructions to recover your computer.
    Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
    I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
    This was taken straight out of the manual for your model, which can be found here.
    Acer eRecovery Management
    Acer eRecovery Management is a tool to quickly backup and restore the system.
    You can create and save a backup of the current system configuration to hard
    disk, CD or DVD. You can also backup/restore the factory default image, and
    reinstall applications and drivers.
    Acer eRecovery Management consists of the following functions:
    1 Create backup
    2 Burn backup disc
    3 Restore and recovery
    This chapter will guide you through each process.
    Note: This feature is only available on certain models. For systems
    that do not have a built-in optical disc burner, plug in an external
    optical disc burner before entering Acer eRecovery Management
    for optical disc-related tasks.
    When using Acer eRecovery Management, you may be prompted to enter the
    Empowering Technology password to proceed. The Empowering Technology
    password is set using the Empowering Technology toolbar or when first running
    Acer eLock Management or Acer eRecovery Management.
    Create backup
    You can easily create full and fast (incremental) backup images of your system
    configuration to hard disk from the main Acer eRecovery Management screen.
    Note: Fast (incremental) Backup is only available after a Full
    Backup is made.
    1 Press <Alt> + <F10> or select Acer eRecovery Management from the
    Empowering Technology toolbar to start Acer eRecovery Management.
    2 In the Acer eRecovery Management window, select the type of backup you
    want to create using Full or Fast.
    3 Follow the instructions on screen to complete the process.
    83
    English
    Burn backup disc
    Using the Burn Disc page of Acer eRecovery Management, you can burn the
    factory default image, a user backup image, the current system configuration,
    or an application backup image to CD or DVD.
    2 Switch to the Burn Disc page by selecting the Burn Disc button.
    3 Select the type of backup (factory default, user, current system,
    application) you would like to burn to disc. Choosing to burn a user backup
    will burn your most recently created backup image to disc.
    4 Follow the instructions on screen to complete the process.
    Note: Create a factory default image when you want to burn a
    bootable disc that contains your computer's entire operating
    system as it was delivered to you from the factory. If you wish to
    have a disc that will allow you to browse the contents and install
    selected drivers and applications, create an application backup
    image instead — this disc will not be bootable.
    The restore and recovery features allow you to restore or recover the system
    from a factory default image, from a user created image, or from previously
    created CD and DVD backups. You can also reinstall applications and drivers for
    your Acer system.
    2 Switch to the restore and recovery page by selecting the Restore button.
    3 Select the backup point you would like to restore from. You can also
    choose to recover the system from a factory default image, recover from a
    previously created CD/DVD or reinstall applications and drivers.
    Dec 20, 2009 | Acer Aspire 5720 Notebook
    Restoration disk
    Restoring the PC to its original state by doing a system recovery ! Just make sure you back up your important data if you can before doing the system recovery !
    1. Plug in the AC adapter.
    2. Turn the system on
    3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
    4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
    5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
    1. Enter the password created when eRecovery was first started.
    2. Read the on-screen warning and choose Yes.
    3. Click Next. The recovery process will start.
    When recovery is complete the system will re-start and will need to complete the setup of Windows.
    When setup is complete a process will clean up the recovery files.
    Please be patient as this process can take 5-10 minutes or longer.
    1. If recovery cd/dvd's were created, they can be used to restore the system.
    2. Insert disc 1 and follow the prompts.
    Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
    Computers & Internet Logo
    88 people viewed this question
    David Payne
    David Payne
