Question about Apple iBook Mac Notebook
Macbook model A118 System powers up, startup sound plays, Apple logo appears, the throbber appears, system fan starts to race, system shuts-down. IMHO this looks heat related i.e. the CPU Fan is racing, but thats the only outward sign. Anyone else see this problem or concur with the diagnoses?
    Guru:
  • 1,705 Answers
Quite common in all pc's. You can check the fan yourself. Disconnect all power sources including battery.
You'll need to earth yourself to prevent static discharge. (Loose copper wire, one end round your wrist the other attached to a radiator or water pipe)
Take any plates off the bottom of the laptop you can and clean our all the dust and fluff that's accumulated especially around the CPU and Fan area making sure all vents are clear.
If that doesn't work, you have to go a little further.
You'll need to purchase some heat sync compound/paste.
Remove the CPU fan and Heat dispersal plate.
You will probably see some dried up goo, that's the old heat sync paste, its been cooked. Clean it off the CPU and the heat dispersal plate, spread the paste on both the cpu and the heat dispersal plate to form a good interface and re-assemble.
For cleaning I use isoproprial alcohol, is softens without soaking and evaporates fairly quickly; and a soft lint free cloth.
Before you start have a look on You-Tube, it has loads of videos which will show you how to do it.
Posted on May 04, 2010
Will not boot to safe mode imac g4
Starting up in Safe Mode Follow these steps to start up into Safe Mode.
  1. Be sure your Mac is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup sound, press and hold the Shift key. The Shift key should be pressed as soon as possible after startup, but not before the startup sound.
  4. Release the Shift key when you see the Apple logo appear on the screen.
After the Apple logo appears, it may take longer than usual to reach the login screen. This is because your computer is performing a directory check as part of Safe Mode.
To leave Safe Mode, restart your computer without pressing any keys during startup.
Sep 25, 2014 | Apple Computers & Internet
My Macbook pro turns on but then gets stuck at the Apple logo with the loading gear and never finishes loading.
See if you can start your Mac in safe mode:
Shut down your Mac and wait 10 seconds.
  1. Press the power button.
  2. Immediately after you hear the startup tone, hold down the Shift key. You should press the Shift key as soon as possible after you hear the startup tone, but not before.
  3. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
To leave safe mode, restart your Mac normally without holding down any keys during startup.
If you can boot in safe mode, you have something on board your computer that's interfering with startup. If you've recently installed software, system extensions or 3rd party preference panels (Adobe and Microsoft stuff is notorious), try to disable or de-install it. If you can't get booted in safe mode, you may have a hardware or memory problem that might require technical repair. Repost your progress.
Apr 05, 2013 | Apple 13.3 MacBook Pro Notebook Computer ...
Hi,\r\ni have a problem with my macbook air when
Try restarting your computer while holding down the X key. This may force the computer to start up using your Mac OS X system. If it does, release the X key, then open System Preferences and click Startup Disk. Make sure your Mac OS X system is selected. If you are unable to start up using the X key, restart your computer and immediately press and hold the Option key. Release the Option key when icons start to appear in the center of the screen. Select the Mac OS X system disk, then click the forward arrow to continue starting up.
If the above attempts to reselect your Mac OS X startup volume are unsuccessful, try resetting PRAM. Shut down your computer, then turn on the computer and immediately press and hold Command-Option-P-R until you hear the startup sound for the second time. Open System Preferences, click Startup Disk, and select your Mac OS X volume.
Hope this helps. If none of these options fix your problem, bring your computer to an Apple store, they are always very helpful and almost never fail to fix the problem!
Mar 11, 2011 | Apple MacBook Air
New application quites upon launch on macbook OS 10.6
Welcome.
First of all, make sure that the application meets the system requirements.
Restart the computer by choosing Apple Menu - Restart. Also you can try to Restart in Safe Mode.
To Restart in Safe Mode:
  1. Shut down your computer and wait 10 seconds.
  3. Immediately after you hear the startup tone, hold down the Shift key.
  4. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
Hope this helps!
Dec 14, 2010 | Computers & Internet
My apple macbook air will not reboot. it turns on but does not reboot completely then it shuts down and tries to reboot again and again. apple logo appears and the spinning icon rotates but never goes...
It may be a possibility that the hard drive has gone bad or a connection to the hard drive. The spinning wheel and apple signify the kernel boot, or in other words, the process in which the machine finds the hd and os/software.. you need to bring your machine into an authorized repair center to have a system diagnosis to verify that no other parts of the machine are bad. That model is notorious for having bad hd's.
Nov 24, 2010 | Apple MacBook Air
How do you start in safe mode? I started with power and shift. Then what do I do?
To start up in safe mode:
Nov 13, 2010 | Apple MacBook Mac Notebook
Help with my macbook air, it shows only the apple logo and a spinning wheel
Power the machine down. Press the power button to turn it on. After you hear the startup chime, press and hold the shift key. This will trigger an extended file system check and a safe boot. Continue holding the shift key down until you see the spinner, then you can release it. If it doesn't boot completely after this, you will have to bring it in to an Apple-certified tech for repair.
Apr 01, 2010 | Apple MacBook Air
Before my computer use to get really hot and then my computer use to shut down. I think there is a problem with the fan. Today when I switched it on the apple logo will come with the sound when it starts....
there have been problems with MacBooks suddenly shutting down since the first Intel based MacBooks were made. It is called RSS. (Rapid Shut Down Syndrome). The cause of which I have learned in the following excerpt.
Since isolating the heatsink as the cause of the MacBook’s Rapid Sudden Shutdown (RSS), readers have isolated the specific part of the heatsink that is causing the problem, is actually the CPU thermometer itself. Essentially, the heatsink can expand during use, and comes into contact with the lead from the thermometer’s sensor cable. A short circuit results, and the SMC pulls the plug. Once the system cools down, the heatsink resides and the contact is broken. This also explains why sometimes you cannot immediately power the MacBook back on. The heatsink is still in contact with the metal lead.
Apple’s solution to this is to realign the location of the thermometer and cabling on the heatsink so that it does not short circuit. That is why the new heatsink is necessary. In the view of this writer, it warrants a public recall. Any user can produce easily the scenario that causes the MacBook to crash, even with pre-installed applications such as iLife.
My 2 cents,
Thanks
Fame !
May 17, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
The loading 'logo' wont disappear. pls help.
Hold the power button down. Keep it down until the unit powers off. Then press power to start the machine up, and as soon as you hear the starting chime (boooong) press Command+Option+P+R and keep them held down until you hear the startup sound 3 times. Then you can let go and it should start normally.
May 02, 2009 | Apple MacBook Air
Macbook Startup Never ending Apple Logo and Circle
try holding down the alt(option) key when starting up it should give you a list of startup options, it sounds like you dont have a astartup disk (an operating system) installed.
Dec 12, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple iBook Mac Notebook Logo
1,144 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
