Question about Fisher Paykel Eco IWL16
Fisher & Paykel Model GW509AU
Was working fine stopped (at what stage i dont know ) wasnt watching but bowl was full of water no lights were flashing that i could see turned power off at the wall and then on again still nothing flashing ,
pressed power putton on machine no flashing just a slight humm no lights would stay on couldn,t empty the bowl so i rang fisher they said it would be $200 just to look no promisses so i thow it out the back and brought old simpson that we had replaced with fisher and are now using it can any one help me with what could be wrong with this
6ya staff
SOURCE:
Anonymous
  • 145 Answers
SOURCE: I overloaded my washing machine!!
Hi Tracy, welcome to Fix ya.
I believe know exactly what happened here- one or more of your tub support rods has broken and that caused the tub to drop down. Those are actually pretty easy to change yourself! Lift the lid, look for two plastic caps, one on each side, that cover the screws the secure the washer top to the cabinet. Pop the caps off, take out the screws. Now the whole top can be opened up (it's on a hinge of sorts) and now you can see the main basket/tub assembly. The rods fit in a recess on the tub at the bottom and on the top of the rods, the triangular plastic sits in each corner of the machine. There are no tools needed, these rods come off very easily.
You can get a set here: (They are sold in sets of 4 and should be replaced as a set)
http://www.fisherpaykelparts.net/ecart/item.php?item_id=218&category_id=46
I hope this info is useful to you.
Posted on Feb 28, 2009
seakish
  • 492 Answers
SOURCE: when the washer (fisher & paykel gwl 11) goes into
Try unplugging the washer to reboot the curciut board. Leave unplugged for 5 min. Then replug and select only one setting. Multiple setting selected in a short period on time will confuse the little brain in the board. Reboot to fix. Be patient!
Posted on Apr 30, 2009
Anonymous
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
luisa_sgro
  • 713 Answers
SOURCE: dismantle washing machine
b4 u remove bowl try this 1/ buy 2 pkts bicarb of soda. 2/pour into empty bowl of unit. 3/select high water level 4/ select hot fill. 5/ start cycle 6/ let it wash for 5 to 10 mins then turn it off, do not let it get to rinse and drain the water away. leave it over nite with water still in it, in the morning restart program and let it do a normal cycle with no clothes in it. it will not refill as it already fill of water.please reply to see how u went or 4 more help
Posted on Apr 09, 2010
msker833
SOURCE: fisher and paykel 7.5 smartdrive washing machine, no power
my smart drive GW 509 au does not fill up with water. Water goes in but only for 10 seconds then stops and does it aginthen it starts to try and wash.
Posted on May 01, 2010
Fisher & Paykel Kelvinator Smart Drive 601. Machine does not complete full cycle. Stops at most stages and beeps. Seems to have trouble with water intake. Hoses have good water pressure when...
the magnetic switches may be warn. in hard water areas they can block up and stop working. you may need to change them or take them out and stick them in some vinaga and see if it will soffen the hard crust off the inside of them out.
Oct 06, 2013 | Fisher and Paykel Washing Machines
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
Washing not getting clean
ok, try this before you consider removing the bowl. 1st-- buy 2 pkts of bicarb of soda. 2nd---make sure machine has no clothes in it. 3rd-- empty the 2 pkts of bicarb of soda into the bowl. 4th-- select traditional wash mode , high water level, hot water fill. 5th-- push start. 6th-- let it fill and wash for about 5 to 10 min, then turn the machine off. DO NOT LET THE WASH CYCLE GET TO THE DRAIN OUT STAGE. ok now the machine is full water and bicarb of soda and turned off, LEAVE IT TILL THE NEXT MORNING.-- In the morning select traditional wash mode, high water level, hot fill , then push the start button. let it go thru the complete cycle and all the lint and dirt should be removed from the bowl. by the way once it has started to wash lift the lid and see if the agitator is working. good luck and please reply to tell me how you got on.
May 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel washing machine not working properly
It's most likely the Lid switch (reed switch). Does it come up with a fault code or beep at all? if so there are eight LEDs reply with the lights eg 00100010 1=on 0=off cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel will not drain
I had the same problem. After cut the power off for at least 60 seconds and then back on, as the manual suggests, the problem remained. Therefore I started putting the clothes out and bailing the water out. Once the water was down about half way the pump started working. I suspect the sensor was "stuck". I cycled the washer without clothes and it worked fine. Still working after several loads of laundry. The water level sensor will probably need replacing sometime soon.
Dec 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Eco IWL16 Logo
329 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
