Question about Refrigerators
Water in floor
Have a side by side jen-air== about every 3 to 4 days i find about 2 cups of water in the floor under the door on the freezer side,,i found the tube coming down the door and it connects to a tube under the frig. it is not the tube leaking,,i put my hand under the freezer side of the the front and felt a wet spot on the frig. there is no wet spot anywhere else under the frig.at all,, wher is the water comming from?
    President:
  • Refrigerators Master
  • 2,651 Answers
Sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 26, 2008
I have a Jenn-Air JFC2290v water appears on the floor front right corner, sometimes front left corner as well. I have moved the unit and have not found any water under it. This has been on going for...
I bought the same JFC2290 model and it says "Auto defrost". Mine is only 10 months old and it starts having exactly same problem already. Water leaks and I have to clean my hardwood floor twice a week. I will never own Jen junk again!
Nov 09, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
Water leak from under door
When your refer defrosts a couple times a day it produces about a quarter of a cup of water each time.This occurs in the freezer section.The water travels down a drain pipe (or tube) that leads to a drian pan in the bottom of the unit. It is collected and evaporates from the heat of the motor.
If the drain is plugged water will form inside the unit itself.If the drain tube has somehow moved and not allowing the water to collect in the drain pan it will go on the floor.Either way,if the drain is the problem the amount of water should be pretty small, no more than a cup or two.If you have an icemaker or ice and water through the door and the amount of water on the floor is more than a cup or two. I would find the water shutoff for the supply line(probably behind the unit in newer homes)and turn it off.Clean up the water and wait a day.If the water goes away assume that one of the plastic lines in the unit that carries water to the icemaker or door is leaking.If the water continues I would suspect the drain.The only way to check the drain is to unplug the unit and remove the cardboard back,locate the drain pan and see if water is present and that the drain line is in it's proper place.
If one of the water lines is leaking you will most likely need a service tech.
Also it's best to turn the icemaker off by lifting the arm or switch before you turn the water off for testing.
Mar 18, 2010 | Hotpoint HSS25GFP Side by Side...
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Water on floor at front right of refrigerator
Yep got a wood floor 1/2 way up do to water leak.
First lets decide where your leak actually is.
Fact: If the drain pan is dry does not mean that the water being disposed of during defrost is not getting to the pan, It could also mean that the water that is reaching the pan is being evaporated like it is suppose to be. So we have to find your source of the water first then decide on what is causing it.
Areas to consider:
1"Inside" coming out the front from under the door? This is most likely a stopped up drain pan. A cold area that is not suppose to be cold like when you have a freezer coil that is suppose to be defrosting and is not... See below for a more complete ideas list of things to check under Possibility.
2"Outside not underneath" The corner of the door also could indicate (if you have water in the door) a worn out water line or a kink in it that has finally started to leak. Turn off the water to the refrigerator for 2 or 3 days and see if the problem disappears. If so you know whats going on and can approach it from the door area.
3"Outside underneath" The corner could also be where the water is running to from someplace under the fridge. The drain pan drain line is the most common. Inspect it and repair as needed, maybe its just not over the pan. A new house keeper not acquainted with this box may have knocked it out during vacuuming just put it back over the pan. IF The sealed system has had refrigerant added it could be from an over charge and frost on the suction line defrosting during a shutdown.
Possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the ice buildup is allowing conductive cooling into the refrigerator section and therefore is allowing condensation on the refrigerator wall or ceiling.
4 The refg section has a heater (possibly not positive) in the area of the door frame, or it may have a "power saver" switch. This switch and the heater (if it has a heater it may not have a switch) are designed to stop condensation on the refridg while running. I fit is placed in the "power save" mode it turns off the heater. But, if you live in extream humidity (Great lakes east side or Gulf coats Houstion...) the humid air will condensate water out and it will collect and settle on the floor.
5 Door gaskets are not sealing especially on the bottom of the door. This allows warmer air into the fridge section and it is condensation on floor under the crisper.
If you check all of these items and still cant find it please post back and tell me what you did find. So I can help you more. Please rate me as much as possible as Im trying to keep my average up and do the things that will actually educate and help people.
THANK you for using fixya and good luck..
Mar 22, 2009 | Frigidaire FRS26R4A Side by Side...
Leaking water in bottom of freezer
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Jan 06, 2009 | Kenmore Refrigerators
Water gushed out freezer door, possible solenoid problem?
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Nov 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Jenn-Air JFI2589AEP
hi thanks for the question if your getting water now 2or 3 times the drain hose going from the freezer to the drip tray under neath is clogged also the drain hose may not be in its proper place in tray possibly when it was delivered remove back panel behind fridge and locate drain hose and re install in proper place in the pan thanks the appliance doc
Aug 19, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore freezer peeing on my floor
  • if the door was not closed correctly for a while then a lot of condensation will be accumulated on the freezer coils.
  • then when going into defrost it melts this ice/frost and overflows the pan or container under the machine which relies on evaporation to dispel  of the water.
  • empty the pan under the refrigerator if you can, then give it another day, it will get back to normal.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Refrigerators Logo
250 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
