Question about RCA F25432 25" TV
Is there a focus control on the back? - RCA F25432 25" TV
    Problem Solver:
  • 6 Answers
You have to remove the back panel to see the fbt there shoud be a focus control there
Posted on Aug 13, 2010
All the pictures are blurry the auto focus isn't working
You may have put the camera on manual focus. Two ways to do that.
1. There is a switch on the lens which allows you to select auto or manual focus. Be sure the switch is set on A or A/M. If it's on M, you are on manual focus.
2. In you menus, there might be a mode which is manual focus. Look in your manual index under Focus, manual. There might be a setting in the Focus Mode menu.
You can also try resetting your camera. This will put most things back to factory default mode, including the focus mode.
When playing around with controls, go step by step through the manual and try things out. Be sure to set the control you were playing with back to default unless you really understand that setting.
Apr 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
Is there a focus for my F19251GY TV
Hello
Yes, of course there it is in every TVs. The focus adjustment in TVs determine the clarity of the display. It is a service adjustement and if you want to adjust it you should open your TV. It can be located at the Line Output Transformer [LOT], and integrated to it.
There will be two adjustable controls can be seen on the LOT. Out of which one is Focus control, and other is Screen control. Both are marked. Normally Focus control is placed on the top side and Screen control to bottom. Both controls are interactive, that is adjusting one will effect the other a little.
If your TV is out of focus, you just open its back cover and locate the said control. It will be usually marked as focus. Adjust a little while looking at picture to get a well defined focus. For this adjustment, take its menu display as reference rather than a moving object. Adjust it to get a well defined display. Place a mirror in front of your TV, so that you can see the image on it from back side.
A defective CRT [picture tube base] "socket" may also be the cause out of focus picture. It can be located on the base card of your TV, and can be detached from it desodered. If the above said adjustments did not give any results, the CRT Base may be defective. If base socket is defective, you can hear a very slght "shhhh" noice from it as you advance the focus control. Try to find out and rectify the problem. Ok
Oct 26, 2010 | RCA F19251GY 19" TV
Looking to locate fuse that controls rear hatch on Ford Focus Station Wagon
there is no seperate fuse for the hatch, it is controlled through the body control module.
Mar 12, 2010 | 2002 Ford SVT Focus
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
How to focus manualy
remove the back,there is a wing nut you undo on the lens on each crt.you rotate the lens by
pushing left or right and pull up the menu and
visually rotate the wingnut by watching the menu on the screen by moving the wing nut
left or right.then you also have electrical focus
these 3 focus controls are located by removing
the front speaker cover and are located on the
right side.be careful not to turn the screen
controls that are with the focus controls.and
pull the menu up and adjust each control
individually.
the lens of each crt
Jul 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Sony kv36hs500 does it have a focus ajustment? i had the high voltage chip replaced t v doing fine just not as clear as it was.
Yes, It has focus control at side of fly-back transformer. Rotate focus control in both sides to get maximum sharp focus.
Feb 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Focus the picture on a Model 27GT619 Television
The focus control is on the flyback transformer (Usuallly black or brown with three wires coming out of it. The bigger wire goes to the pix tube with a rubber cap at the end.) The focus control is on the side. There are two. The top is focus. Good Luck!
Jan 13, 2009 | GE 27GT619 27" TV
I have a Zenith C27A24T the picture is out of focus.
If there is no other problem, he probably touched the focus adjustment in the back of the set. Open up the back and locate the flyback transformer (part with large red wire coming out the top). There will be 2 adjustment controls on it. One should be labeled screen, the other focus. Adjust the focus until crisp.
Dan
Sep 04, 2008 | Zenith C27A24T 27" TV
Samsung 753S focus problem
Focus controls are on the back of the flyback transformer. You may have bumped one while the back was off. Due to dangers working on live circuits I recommend you have a service professional adjust the focus.
Sep 04, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
RCA F25432 25" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
