Question about Beyond Micro Mobile / 250GB / 7200 / 8MB / Black / USB 2.0 / External 250 GB Hard Drive
I have a BeyondMicro 250gb Hi-Speed USB Speedano 3 external Hard Drive. Using Rebit, I have been backing up a WinXP Home edition pc. I now have a Win 7 pc which does not seem to recognize my files. What can I do?
SOURCE: Won't recognize my USB
Simpletech USB 2.0 500GB (bought today) took several on/off then it puffed a small (smelly) smoke and fired up. I had rebooted the pc before this happened. I'm not sure if that was part of the problem or if the drive just needed the on/off action to wake it up.
Reading these posts however makes me wonder how long, and if this thing is going to work!
Posted on Dec 22, 2007
iomagic
  • 8 Answers
SOURCE: DRIVERS FOR IOMAGIC 250GB (WIN XP)
The I250HD35 is plug-and-play with Windows XP. That means that all of the drivers needed to run your hard drive are included in Windows.
If your computer is asking for drivers when you plug in your drive, one of two things is probably happening:
1) Windows XP doesn't know where to look for the right drivers
2) Your drive has malfunctioned
The easiest way to assess which of these is happening is to take your drive and plug it into another computer that is running Windows XP. If it is detected properly on the other machine, then your computer doesn't have the right drivers or is looking in the wrong place for them. If it doesn't, then I/O Magic will be happy to replace your drive if it is still within the warranty period
If it is detected properly on another Windows XP machine, then when it asks for drivers, make sure to point it to the WindowsINF directory. This is where the default drivers are located.
If your drive is not detected properly on the other computer, your drive is probably experiencing a hardware malfunction. Please visit the I/O Magic website at www.iomagic.com and click on Support for specific return information.
Have a nice day,
I/O Magic Technical Support
Posted on Sep 10, 2008
JulesPCaut
  • 702 Answers
SOURCE: Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Posted on Feb 23, 2009
Dead Surfer
  • 6 Answers
SOURCE: I need a driver. Just got windows 7 and it doesn't
The only thing to do is make sure you go through all Windows Updates. Then go to manufacturer's website and download Win 7 drivers. Then install via add new hardware. Sounds more like a USB driver issue...
Posted on Dec 25, 2009
lock123
  • 6831 Answers
SOURCE: I can't access data off my portable hard drive (model HD-337-U2C)
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Jul 16, 2010 | SimpleTech Signature Mini 250GB External...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
External Hardisk Maxtor 4 One Touch not detected
Have you tried different USB cables with the drive? If the drive is self powered (no ext power supply) which I think that one is, then it needs a really good cable to draw the 5 volts from the USB port. If you have tried a known working cable, then it could be the USB controller or the disk itself. You can buy the USB box on eBay really cheap and move the drive over.
Apr 13, 2009 | Computers & Internet
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Partition external 250gb drive
why would you want partition it??? XP will recognise the 250. Partition was useful for win 98, but pointless excercise with XP.
Aug 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Verbatim 250GB External Hard Disk not recognized by PC
Almost always, when a USB drive doesn't assign a drive letter in MY Computer the issue is a Mapped network drive using the drive letter the USB drive is attempting to use.
With the drive connected, open DISK MANAGEMENT find the USB Drive, right click it and assign it an available drive letter.
Jun 12, 2008 | Computers & Internet
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 30, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Beyond Micro Mobile / 250GB / 7200 / 8MB / Black / USB 2.0 / External 250 GB Hard Drive Logo
190 people viewed this question
Top Beyond Micro Computers & Internet Experts
David Payne
David Payne
Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
