Question about Emerson (33416-78414) Fan
Motor hums but blades don't spin - Emerson (33416-78414) Fan
  • 577 Answers
It should have something in motor block blocking the motor to turn.
when it is OFF position ,you try to turn it by hand to see if it spins freely or not ? You may hear a sound of friction that blocks the motor. if this is the case try to find a local electrical expert to unblock the motor..
Good luck.
Posted on May 04, 2010
2 Suggested Answers
  • 347 Answers
SOURCE: my lasko fan stopped working after a power outage.
check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
Posted on Aug 30, 2009
My insinkerator is humming and not working. I bought the wrench and keep playing with it but it it stuck. My son insists that the engine is seized but I feel if it were seized it would not turn on at all....
Your Badger 5 spins the blades counter clockwise. If you want to dislodge an item stuck in their, you have to spin the blades clockwise. I use the handle end of my plunger to do this. If it turns free with the handle, it should work when you turn it back on. If you don't hear it hum any more their is a little red reset button on the bottom of the motor housing you must press to reset it.
Sep 03, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
CKJ-361A GOODMAN CONDENCER UNIT (13 YEARS OLD): RESET INSIDE BREAKER, WENT TO UNIT, NO SPIN-HUM ONLY, GAVE FAN BLADE A COUPLE OF SPINS=STARTED WORKING, RAN FOR APPX. 30-45 MIN, STOPPED, TRIED BLADE...
Replace the capacitor inside the control panel on the outside unit. The top of the capacitor may be puffed up.
The fan motor may also be going bad. Change the capacitor first. It will have to be changed anyway if the motor is bad.
Aug 21, 2011 | Heating & Cooling
My tablesaw will no longer run. I plug it in and turn it on, the blade partially moves and I hear a humming sound
The motor is receiving power, and that is the humming noise.
The humming sound also says the motor is overheating and will burn out.
Turn saw off.
Use hand and manually rotate blade to see if it rolls free.
For example on my saw, the blade barely turned because a bearing was rusted.
I soaked the bearing in wd-40 and 3-in-one oil and salvaged it.
Look for oil ports on each end of motor, and on bearings.
Clean pulleys and belt that connect blade to motor.
If your blade rolls free, and the motor shaft moves freely, then the motor winding has gone bad, so replace motor.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on table saw or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | Craftsman 10" Table Saw
MOTOR HUMS. BUT BLADE NOT SPINNING.
See if you can turn the blades or reach a knife balde in to turn the blades....if something has jammed them.... get it removed... if they spin feely, then the motor is bad and replacement will probably cost more then a new one...
heatman101
Nov 30, 2010 | Krups 203-42 Electric Blades Grinder
The disposal only hums. I can turn the blades inside so there is no food stuck. I know there is a reset button but cant locate it.
I had the same problem, it was just humming, then after a few second the on board circuit breaker would cut out. After a little while I could hit the reset button and it would just hum again.
It turns out that the base of the disposal was jammed. There are 2 blades on the top that should spin freely, but the base plate that the blades are attached to also spins. In fact, that's what the motor drives. The two blades on top are not powered, they just flip back and forth as the base spins. So get a broom handle or a strong wooden spoon, stick it down in there, and try to pry the base plate free so it spins. That should do it.
Oct 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Outdoor unit hums but fan doesn't turn. Nothing heats up but the fan just won't turn and is there a spot to oil the fan on the motor
The fan motor on the outside unit should be a sealed motor. If the unit is just humming is the humming from the compressor or from the motor being locked up. You could try spinning it a few times with the power off to see if this might get it to run and spray some penetrating oil under the fan blade right where the shaft comes out to the fan blade.
Dec 24, 2009 | Heating & Cooling
Unit hums. getting electric but blades
Hi, i,ve got exactly the same problem, did you manage to find a solution?
Oct 28, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Motor can be heard going but the blade wont spin!!
There is usually a pin in the shaft of the motor, that corrosponds with a slot in the fan blades, it sounds to me like either (a) the pin somehow came out, or (b) the slot in the blades is rounded. Hope this helps
Jul 15, 2009 | Patton 20" CVT Performance Air Circulator,...
Emerson (33416-78414) Fan Logo
393 people viewed this question
Top Emerson Dryers Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jim Thurston
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Emerson Dryer Expert? Answer questions, earn points and help others
