Question about Poulan "Poulan" Pp325 17" Gas Brushcutter Trimmer
I need help on restringing the Poulan Pro 350 (double string) I'm not sure if the string goes in the same direction or one of them goes in opposite direction
    Sniper:
  • 52 Answers
Wind them both in the same direction.
Posted on May 04, 2010
How do you rewind the string on the black and deckder grasshog
It's annoying I know, but there should be a little notch in the spool, wind the string evenly round one groove. notch it, then do the same on the other groove but in the opposite direction. Hope this helps.
Jun 28, 2015 | Black and Decker USA BLACK&DECKER GH710...
Which way does my poulan pro pp130 spin?
look on the shield. one side will have a small blade for cutting of the extra string. it will spin in the direction that causes the string to hit the sharp side of the blade.
Jul 25, 2014 | Garden
Poulan25cc 16 inch how do i rewind trimmer line on my poulan 1500 gas trimmer
You should wind it on the spool the opposite direction that it spins while operating it. If you wind it in the same direction as the spin, the line will come off the spool when in operation.
Jim
Jul 29, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan 550 will not stay running. Changed diaphragm and gasket with no improvement. New gas new plug.
Double check the muffler and be sure it isn't stopped up by what we call dirt dobber nest here in the south. I had a string trimmer once that did the same thing and that was the problem.
May 02, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
Trying to replace the fuel line and the primer hose both were rotted off not sure what goes where on my poulan pro ppb200 31cc string trimmer there are two lines into the tank the primer wont fill i have...
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Aug 07, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
String for a Poulan Pro PPB330
Pull your spool off, and look next to the notches on the bottom of the spool. The decimal number is the size of line that you can use. Some spools will have more than one size listed; they can use either size.
Best regards, --W/D--
Aug 21, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
How do you wind replacement line to the Poulan Pro String Trimmer?
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Poulan "Poulan" Pp325 17" Gas Brushcutter Trimmer Logo
327 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
