Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
WP Ultimate Care II model #LSB6500PW3 sticks when spinning
I have a WP Ultimate Care II model #LSB6500PW3 and I just had the coupler replaced but now it won't spin. It fills and agitates and then instead of spinning the water out it just drains it. If I go and open the lid I can hear it click and then when I close it the washer does start spinning. I have looked for answers online and some say it may be the clutch and others say that it may be the lid switch. Any ideas??
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
docjohn174
  • 943 Answers
SOURCE: Lid Switch
hithanks for the question The lid switch is located under top on right side if you open the lid you will see a small plastic plunger on the lid this plunger is what activates the lid switch Thanks for your question hope thisanswers your question The appliance doc
Posted on Sep 11, 2008
aborcass
  • 2651 Answers
SOURCE: WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Posted on Jan 25, 2009
aborcass
  • 2651 Answers
SOURCE: whirlpool lsb6200kqo ultimate care II washing
ummm really soundslke a motor coupler issue, although it appears to be in tact perhaps the slotted ends have rounded out orhave a crack so when torque ofthe motor is applied it slips past causing hte noise. soundslike the motor is running??? and will drain water ??? thiswill provethe motor is runningif drains water..
Posted on Mar 10, 2009
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a wirlpool ultimate care washer the drivecoupler is broke how do I know the tranny is good ? or is the tranny bad and this is what broke the coupler?
most of the time coupler will be fine. but it could be broke b/c of tranny. spin by hand make sure tranny will spin freely both ways. make sure it adjitates and spins. then replace coupler start it up. the good thing is that a coupler is cheap so if it ends up being bad you didnt spend much anyways.
Aug 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not spin.
May be the coupler between the motor and the transmission.
Sep 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer model LLR7144DQO WILL NOT SPIN WOULD THAT BE THE COUPLER
Hi, If it does not spin or agitate, it could be the coupler. If it just sits quiet while in spin cycle, it could be the lid switch.
If it hums while in spin cycle, it could be the pump hung up.
If I can assit you further, please let me know.
VIc
Jul 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate care 2 washer not spinning - not coupler
the transmission has to complete several revolutions before it engages the "spinning gear" but once engaged it should continue to turn the clutch plate as long as it is turned the same direction.
before suspecting the transmission i would first check the plastic piece above the clutch plate.aca822b.jpg
Jul 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
89 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
