Question about RCA 25413RE3 Corded Phone
I can only use line 1 on the phone - RCA 25413RE3 Corded Phone
    Scholar:
  • 45 Answers
There could be a few reasons for this.
First, check the programming on the phone to see if you have turned off the other lines. The phone can be programmed not to use a line or not to ring a line.
Second, you may have a bad wire. Inspect the wires from the wall to the phone for a pinch. Also, look at the contacts in the wall plug and in the phone. They should be straight to make a good connection. Then look at the wire to make sure it's a 4 wire cable. If you look at the connector on each end you should see gold connections in the four slots. If you only see connections in the center two then replace the cable with one that does.
Posted on May 10, 2010
2 LINES PICK UP ON PANASONIC KX-TG4500
Sounds like you have the cords into the back of the phone mixed up. If you have a cord with 1 and 2 plugged into 1/2, great. But then if you have another jack also with 1 and 2, but plug it into 3/4, now you answer line 3 on second phone and line 1 lights up on first phone. Or line rings line 1 here and line 3 over ther. Gotta keep that straight and the jacks have to have identical lines.
Apr 17, 2014 | Panasonic KX-TG4500 Phone
Line 1 and two not splitting
You can find the combiner at Radio Shack Model: T07843 ' Catalog #: 55034722. It may only be online not in the stores.
Dec 03, 2011 | RCA 25414RE3 Corded Phone
Hi, i have a Panasonic KX-T7730 phone. And i have two telephone lines (Line 1 and Line 2) to receive and make calls. I've inaccidentally pressed something and now Line 1 is not working - I am unable to...
From the idle phone press PROGRAM line 1's button and dial 0 1 STORE. That puts line 1 back under the button.
Press PROGRAM or pick up the handset and set it back down to exit programming.
Carl
Apr 19, 2011 | Panasonic KX-T7730 Corded Phone
2 line phone rca 25205re1 only 1 line works not the rollover line
Most likely the problem is the cord from the wall to the phone. There are two types of cords and they look almost identical. Look closely at the connector. A single-line cord will have only two gold pin at each end. A two-line cord will have four gold pins at each end.
You need a two-line cord to get both lines from the wall to your phone. Since you have had the problem with several phones, that is the most likely cause.
Jan 14, 2009 | RCA 25205RE1 Phone
RCA Phone model 252025 - displays Answer... on line 1
The Thomson folks said to reset the phone. Here's how: unplug power, then the phone line, then remove the batteries. Wait 10-15 minutes. Replace the batteries, then the phone line and finally, the power.
Note: We have 2 phones with these two lines and had to reset both of them to clear the "busy" on Line 1.
Sep 05, 2008 | RCA 25205RE1 Phone
Having troubles getting the caller ID to work on line 1 of the Nortel Venture 3 line phones. Please help!
lisactc - Assuming you have called ID service on line 1, swap line 1 with line 2 or 3. If the trouble moves to that line, you are not subscribed for called ID on line 1. If the trouble stays with line 1, your phone needs to repair.
littletrees - Make sure you are using a 16 V ac power adapter.
Aug 20, 2008 | Lands Phones
We have an older AT&T spirit phone system, sometimes line 1 will not work, I disconnect line 1 from the phone system box and plug back in, I then get a dial tone but the line will not disconnect, this...
There is most likely a problem with your control unit and the CO line 1 will not disconnect. However, to absolutely eliminate all other possibilities, try swapping phone lines 1 & 2 and see if the problem stays at line 1 (which will now be a different phone number) or if the problem moves to line 2 which would indicate a problem with the wiring to the control unit.
Hopefully you do not use all the phone lines in your system and you can move them all down one slot. (line 1 becomes line 2, line 2 becomes line 3 etc...) and just stop using line 1. Otherwise you will need to find a replacement control unit.
Jun 12, 2008 | Lands Phones
GE 29488
Note: Intercom features are NOT compatible when DSL is installed on line 1.You may need to reconfigure it for dsl internet if it is installed on line 1
May 27, 2008 | GE 29488GE2 Corded Phone
Defaults to Line 2
Do you have a second phone? Be sure that phone is not defaulting to line 1. With 2 lines and 2 phones, each phone defaults to one of the lines.
Unplug the phones. Plug in the phone you want to default to line 1 using the L1+L2 jack. Now plug in the second phone.
May 22, 2008 | RCA 25205RE1 Phone
Multi Phone Line Wiring Assistance
unless you are intending on using internet phones you will need to run new wire from the phone box ( on the outside of house) to each Room A and Room B. The general line is already run as I am assuming you already have 1 line in place.
Mar 11, 2008 | Lands Phones
RCA 25413RE3 Corded Phone Logo
78 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
