Question about Garden
Hi, i have an powerforce by ingersoll rand pf1300 electric air compressor. my pressure switch is burnt out and dont know how to replace it
  • 12,061 Answers
Take off the cover of the old pressure switch. Most models of well water pressure switches have a cover that simply snaps off, but some require a screwdriver to loosen a screw first.
Check the pressure switch's settings against the printing inside of the cover. If that solves your issues you are done. If you are still having problems, move on to Step 3.
Turn off the power to the switch by flipping the breaker. Check to be sure that the power is off with a voltmeter.
Remove the old switch making sure you note which color wire is in what position. You may want to mark the wires with colored electrical tape so you know which switch location to reconnect the wires.
Bring the switch to the hardware store and find a replacement that covers the same pressure gradient as the switch you are replacing.
Install the new switch according to the manufacturer's directions. Be sure the mounting and wires are in the correct place. Use wire nuts and a screwdriver to complete the installation.
Flip the power back on to the switch and test to make sure it is working properly. Be sure the settings match what works for your system or what the manufacturer recommends. Remove all electrical power from the circuit feeding the air compressor. Locate the correctly rated pressure switch on the air compressor's storage tank. No valve must be installed between the switch and the air storage tank. A short pipe nipple is used to conduct the air from the tank into the pressure switch. Typically a ¼-inch diameter pipe is pre-installed on the storage tank for the pressure switch.
Use the Teflon tape and install two or three rounds of the sealant tape over the male pipe threads. Screw the female fitting of the pressure switch onto the pipe nipple. Tighten with the crescent wrench. Remove the top cover of the pressure switch.
Observe the set of four contacts, small copper discs, on the interior of the pressure switch. The contacts are electrically connected together on the topside of the copper discs. Each set of discs has a corresponding screw connector. Think of each set of contacts like a light switch. One set of contacts will be used for each wire to be switched. Strip back the four wires, two wires coming from the power source and two wires going to the compressor motor, with the wire strippers. Remove 1 inch of the plastic insulation to reveal the bare copper wire underneath.
Use the screwdriver to connect the two wires coming from the power source to the two outermost screws of the contacts. These screw terminals may also be marked as "line." Connect the other two wires, going to the compressor motor, to the two inside screw terminals on the pressure switch. These terminals maybe identified as "load". In a 240 VAC feeder circuit the wires do not have to be mated to the switch. In a 120 VAC circuit the white neutral wires must be connected to the same set of contact screw terminals. Connect the bare copper wire or green insulated wire to the green screw on the metal frame of the pressure switch.
Replace the cover over the pressure switch. Apply power to the air compressor circuit. Switch the pressure switch to the on position.
http://www.about-air-compressors.com/pressure-switch2.html
http://www.about-air-compressors.com/troubleshooting-your-compressor.html
Troubleshooting links above..
Posted on May 05, 2010
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
I have an Ingersoll Rand 2340L5 and need to know how to have it come on when it gets down to 120 instead of 100
Change the settings on the pressure switch. Brad Brown has a good description of the pressure switch
Nov 22, 2011 | Ingersoll Rand - Rand Type - 30...
Wont shut off
Hi ethang...
Try to adjust the pressure shut off switch...sometimes they can also get a hole in the diaphram and leak enough air to cause a problem, if you cannot adjust your pressure switch to shut off then you will need to replace your pressure shut off switch it is defective.
Please take time to rate me
Sep 08, 2011 | Ingersoll Rand - Rand Type - 30...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
Air leaks from pressure switch after compressor builds full pressure
if its leaking steady from the unloading valve on the pressure switch after the compressor stops you have a bad check valve!replace it and youl be fine,dont forget to depressurize your tank before!!!!! and use teflon tape on the treads to avoid air leaks when you replace it!
Jan 20, 2011 | Ingersoll Rand Single Stage Electric...
I just bought a used ingersoll rand ss3L3 and need to know how to adjust the pressure regulator switch. Also how to set the high and low limits.
if you want more pressure out your hose use the outlet pressure regulator. if you want more or less air put in the tank you can try to adjust the pressure switch. different models are adusted in different ways. there may be a screw between the points that make contact. adjust it up or down to see the direction you need to go. some of these switches won't let you adjust or id they do it won't be much.
Sep 02, 2010 | Ingersoll Rand Single Stage Electric...
My ingersol rand compressor shuts down on low unload sump
check minimum pressure check valve on top of separator cover.
Jun 30, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Cuts off with no reason
hi mate when the reach there working pressure e.g.150psi/10bar they shut off and then when the pressure drops to a pressure of e.g. 100 psi 7 bar they automatically start back up and pump back upto they working temperature or if it dont start at all it could either be a faulty pressure switch or a fualty star delta starter if its 3 phase 415 volts if its 240volt there are only a pressure switch which will be faulty get a sparky in to sort it out there buggers to mess with 415volts 240 volts easy
Jun 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
