Question about Karcher 2500 PSI Pressure Washer
No high pressure
Does not reach high pressure it is the gas powered ithink itis the 2500psi model
  • 3,740 Answers
These pumps are notorious for seasonal problems.
Tip the unit to the point you can pour engine oil into the water inlet connection. What your attempting to do is free up the ball seats in the pump. They get corroded when they sit and lock in place. Adding the oil or a vast amount of WD 40 to the water inlet often does the trick for loosening up the seat balls and springs.
After you add the oil (3 - 4 ounces) or WD 40 to the water inlet line just slowly pull the engine through with the ignition switch off. As the water inlet cavitates add more oil.
Let it sit over night and then take a block of wood and a hammer and tap on the power head. Don't over do it and do it in such a manner your not going to shear off any bolts or break anything. But... be serious with the hammer and block of wood.
Then connect inlet water hose, the pressure hose and test the unit. You may want to purge the oil lubricant into a bucket before you start the engine.
Give it a try and see what happens.
Thanks for using FixYa,
Kelly
Posted on May 04, 2010
Gday folks have a 163CC 2500PSI RYOBI® RPW2400 Petrol High Pressure Cleaner that cuts out after about 5 to 10 seconds Nothing obvious to me. any suggestions would be grateful Thanks Marc
Check fuel delivery to the carburetor--if just drips, check the fuel filter for plugging. Make sure you have fresh fuel in the tank. Hope this helps!
Dec 04, 2010 | Ryobi Garden
Last year around this time I tried to start my
Carburetor is probably gunked up from old gas left in system. It will need some cleaning and / or dissasembly.
Have it repaired at a reputable mower or small engine repair shop. When being stored for long periods, run it out of gas or use a fuel stabilizer in the gas to prevent this from reoccuring.
May 13, 2010 | Honda 2500 PSI Gas Pressure Washer
Commercial refrigeration motor over heating and low suction press
Add 404A to system. It is low on gas. But kep an eye on the TXV for ice buildup. Make sure unit is free of ice before you charge it. It is difficultr to charge a refer system when itis iced up. Rus
Dec 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
95 taurus AC no power to compressor. No voltage detected across 4-wire plug at compressor. Fuse under dash OK.
the systemis trying ot protece ieself for 2 reasons you have high pressure or low pressure with what you have told us here that you have low pressure which in turn means that you are low on freon or high/low pressure swich is bad ... which i doubt very seriously but it can happen id go back with the basics and start from there, Ithink that you are low on freon,thanks and I hope that this helps you.
Sep 10, 2009 | 1990 Ford F250
My Troy Built 2500psi washer will not pump cleaning solution.
Next problem will be the spray head itself. It needs to be cleaned with a small wire from time to time.
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
165 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
