Question about Brother MFC-8220 Fax
When receiving faxes, a black line is being printed down both 11" sides of each sheet. Is this a toner/drum issue?
    President:
  • 3,085 Answers
Yes, replace the drum
Posted on May 04, 2010
Black line down left side of sheet, if i'm copying a page that is and i can't get rid of it no matter what i try i've changed the drum and the toner and still get a line down the whole sheet
If the received fax's are ok and there is no line; and you only get the line when you make a copy....I assume the people you send to are also getting the black line down the page,?? then the problem is in the optics...favorite is some kind of dirt, glue, or corrector fluid on the glass that the original passes over when you make the copy.
Aug 20, 2010 | Office Equipment & Supplies
Hello our Muratec F-320 will print faxes with a
lIFT THE BLACK PLASTIC COVER ON TOP OF THE TONER AND DRUM CARTRIDGES. UNDERNEATH THE COVER CLEAN THE ROW OF "EYES" RUNNING FRONT TO BACK. SHOULD FIX IT...PROBABLY HAVE SOME TONER ON THE GLASS EYES.
Jun 24, 2010 | Muratec F-300 Fax
I changed the toner and now I get a broad black line down the side of the paper when a fax prints.
Clean the charge corona wire on your drum unit. It should be a green plastic handled device located on top of your drum unit. Move it forward and backward ~ 5 or 6 times, then reinstall drum unit.
Nov 10, 2009 | Brother IntelliFax-2920 Fax
Solid black lines on the right side of page
Try sliding the blue tab on the drum unit side-to-side. If that does not cure it, you need a new DRUM UNIT
Oct 02, 2009 | Brother IntelliFAX 4100 Laser Fax
I just installed a new toner cartridge and now all my pages have a thick black line down the right side of every sheet.
the new cart mite be bad:(. Do you have a second cart? next cart placed in the machine properly? Look for a toner band on the drum?
Aug 13, 2009 | Brother IntelliFax-2820 Laser Fax
Lines down the paper HP 4600DN
This means that the problem is with the toner drum. Just try to clean the drum of the toner with cotton. It is green colored rod in the toner. then try to take the print. If still you get the line while printing please either replace the toner or get the drum replaced from a local vendor
Jul 14, 2009 | HP LaserJet 4600dn Color Printer
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
When received a fax, there is a black shade on one side of paper
Take out the toner cart and turn it upside down. Swing away the drum cover. The drum should be clean, if not replace the toner cartridge.
Jan 28, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Poor Print quality - black lines appear on page
If you see black lines on the drum, it is very likely that the drum unit is bad. Replace the drum unit and rest the drum counter. If you wait too long, you will cause toner build up in the fuser and will cost yourself several hundred dollars to get it replaced. More in labor than parts.
Use a soft cotton or very soft paper towel and wipe the excess toner from the drun. If there are lines worn in the surface of the drum, then replace it ASAP.
Nov 15, 2007 | Sharp FO 4450 Laser Fax
Black pages when making a copy or printing something
Have you tried both drum and toner supplies? cause it sounds like a drum fault, if you have tried a new drum and toner, and it is doing it when printing internal reports, receiving fax's and copying then you have a tecnical issue to do with charge and this would likely render machine unecomical to repair (unless you can find a bad contact with drum on machine). If it receives faxs clearly but copys black then it is different issue (ie optics).
Oct 16, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC-8220 Fax Logo
89 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
