Question about Symbol PDT6842-NIS632EU Portable Data Terminal
TCP is down message on a Symbol PDT6846 terminal, unit appears to associate with the access ponit
5 Suggested Answers
SOURCE: Need to reload Symbol PDT 6846 scanners
To configure the terminal Ctrl-C to drop you to a DOS prompt then type cfg11 this will then take you a configuration screen where you can enter wireless and IP settings.
I can’t say about what program you are trying to load. If you get the system to associate then the next step is to configure the host settings.
FUNC-CTL-R at the Connect to Host screen
Password: system
Then you can add host settings.
It’s a shame we fix PDT6846's all the time and if we replace the board reconfigure them for the customer.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Posted on Dec 10, 2009
thesuperdude
  • 97 Answers
SOURCE: Connect PDT6846 to Wavelink COM Server
you can get it from www.wavelink.com they are quite good and still offer the files for the older terminals. however, you may need to get a license from them in order to use it on the pdt.
Posted on Jun 15, 2009
  • 65 Answers
SOURCE: I have a symbol PDT6846 and can not get the unit to flash
this could be a little of a challenge, and there is not enough of space here to write every senario. I can definatelly walk you through this process and determine what is cousing this issue. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Posted on Jan 25, 2010
pctech1
  • 1940 Answers
SOURCE: Terminal cannot associate with AP Problem
The terminal's Status LED indicates the state of the 6800's connection to either of the RF
networks:
  • Off indicates that the radio is working and associated with an access point (Spectrum24) or base station (Spectrum One).
  • If it Flashes red once per second, this indicates that the radio is out of range or not associated with an access point or base station.
If you have multiple portable terminals, and this is the only one with issues making a connection to the AP, then the PDT6846 configuration is probably the issue here, as the unit does not associate when within range of the access point. This problem could also be indicative of either an internally defective RF card or simply a weak signal output from the PDT6846 due in large part to a weak battery.
ACTION STEPS
  1. Verify PDT6846 configuration.
  2. Verify PDT6846 is operating with a fully charged battery.
  3. Warm boot PDT6846 to reestablish radio association.
If problem persists, the PDT6846 requires repair attention specific to the internal radio card.
Rebooting the Device
Try rebooting the device using a Warm Boot. If the Warm Boot doesn't fix the problem, try a Cold Boot.
Warm Boot
A warm boot resets the operating system while preserving the program and data on the RAM disk. This process is similar to pressing the keys on a PC, except that it does not clear the system's memory. To perform a warm boot:
For the 35-Key terminal:
  1. Power the terminal off
  2. Press and hold and
  3. Press and release
  4. Release and .
For the 46-Key terminal:
  4. Release and .
The terminal displays configuration information, copyright, RAM size, and expanded memory RAM size. Other information displayed depends on the operating system, installed device drivers, and AUTOEXEC.BAT commands. If this warm boot procedure fails to restart the terminal, use the Cold Boot procedure.
Cold Boot
A cold boot fully resets the system and clears memory, including the RAM disk. Any programs and data stored in memory or on the RAM disk are deleted. Nonvolatile memory (NVM - the Application EEPROM) is not affected. Caution: This procedure permanently erases all data and software in the terminal unless they reside in NVM. Contents of RAM are lost. To perform a cold boot:
  2. Press and hold , , and Up Arrow
  4. Release , , and Up Arrow.
  4. Release , , and .
The terminal displays version information, copyright, RAM size, and installed expanded memory RAM size. Other information displayed depends on the operating system, installed device drivers, and AUTOEXEC.BAT commands.
Cold-Boot Failure
During a cold boot, the system briefly displays a status line for each driver as it loads in the
format:
0: Driver #.##
The line shows a status value, usually 0, followed by the name and version number of the
driver. If the system halts at one of these lines and displays a status value other than 0, the
displayed device driver failed to load properly.
If such a failure occurs, try cold booting the terminal again. If this does not solve the problem, call the Symbol Support Center.
Here is your User Manual:
http://www.barcodemuseum.com/SymbolTechnologies/Manuals/pdt6800user.pdf
Posted on Jun 15, 2011
Hoe to reboot pdt6840 scan gun
Warm Boot:
- Press the "PWR" button to turn the unit off.
- Press the "4" and "5" keys at the same time.
- While still pressing the "4" and "5" keys press and release the "PWR' button again.
- Release the "4" and "5" button.
- The PDT6846 should perform a warm reboot.
Cold Boot:
- Press the "B", "D" and "A" keys at the same time.
- While still pressing the "B", "D" and "A" keys press and release the "PWR' button again.
- Release the "B", "D" and "A" button.
- The PDT6846 should perform a cold boot.
May 03, 2012 | Symbol PDT6842-NIS632EU Portable Data...
I have a symbol PDT6846 and can not get the unit to flash. I have used three different cradles and done all the proper procedures but have not had any success.
Jan 06, 2010 | Symbol PDT 6846 Portable Terminal
Hello, my handheld symbol pdt6846 need load SLOADI to cingifure, i need to know how
The PDT6840 has 3 files loaded into it at any one time LWP.HEX, UDP.HEX and an application. SLOADI comes up on the screen during boot. You may require reloading of the software to enable this function again.
or TEL 01202 620955
Dec 09, 2009 | Symbol PDT 6846 Portable Terminal
Password: system
or TEL 01202 620955
Nov 23, 2009 | Symbol PDT 6846 Portable Terminal
Frozen PDT6846
Probably not -- looks like corrupt firmware -- it'll have to go to a Symbol/Motorola Dealer for repair.
Oct 27, 2009 | Symbol PDT 6800 Portable Terminal
Jun 05, 2009 | Symbol PDT 6846 Portable Terminal
Stuck in d mode needs to be in c mode
You cannot access C: Drive as this is the eprom of the device and is not accessible. If it shouws the D: prompt it is because it has no applications loaded. Let me know exactly what do you want to do and i will help you.
Apr 28, 2009 | Symbol PDT 6846 Portable Terminal
Looking for mac address on a PDT6846
If you have loaded the radio drivers, exit to dos then type in CFG11 this will take you to the main configuration menu. From there press enter on the first option and voila. There you will be able to find the mac address.
Mar 25, 2009 | Symbol PDT 6846 Portable Terminal
TCP HOst Setup on a PDT6846
The host ip setup is application dependant. You'll need to check with the vendor that supplied your PDT6846 5250 emulator.
Feb 15, 2008 | Symbol PDT6842-NIS632EU Portable Data...
Symbol PDT6842-NIS632EU Portable Data Terminal Logo
448 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
