Question about Refrigerators
My Whirlpool Fridg. Model ED22RF has a problem. The freezer is defrosting and neither side is cold. Sounds like the compressor switch is kicking on for a second and then off but the compressor never really starts? I hear a switch engage then a humming sound for a 10 to 15 seconds and the switch kicks out.
    New Friend:
On the side of the compressor is it a overload or starter on the whirlpool ed2fhexlq01
Posted on Dec 29, 2009
    President:
  • Refrigerators Master
  • 2,651 Answers
Yea that sounds like a compressor issue( under 5 year manufactrue warr.) you can try replacing te overload/relay assy mounted to the side of thecompressor , sometimes you get lucky and it works part number 4387767
Posted on Mar 26, 2008
SOURCE:
My refrigerator freezer wont stay running longer than 4-6 hours. Stops calling for compressor to kick on. any ideas?
i suspect a defrost timer issue but u may want to check the temperature control switch and ur thermistors as well
Apr 17, 2015 | Frigidaire Refrigerators
I have a whirlpool fridge freezer (model 20rud4). It was working fine until about 3 weeks ago and tthen suddenly the fridg is not staying cold eneough. It was originally set to 5 degrees centigrade . i...
it is possible that your fridge has developed a snag in its cooling system. what could be done from your end will be to first of all switch off the fridge for at least 8 hours. allow it to totally defrost. then switch on to see if the cooling returns. if so reduce the thermostat to 7 degrees and check. if the cooling returns then you will need to check for frosting inside due to failure of the thermostat or the auto defroster. if there is still no cooling then your gas has leaked, failureof the compressor, failue of the valves in the compressor could be suspected. Probe with these inputs. Good day
Jun 30, 2010 | Microwave Ovens
My freezer defrosted and the refrigerator is not as cold as it was
That sounds like the compressor start capacitor,relay or overload. It could even be the defrost timer or part of the defrost Adaptive Defrost Control. I will need the Sear Kenmore model number. I will need you to communicate with me and look around the door of the fresh food section for a model number. Sears uses a different model number when they sell a Maytag, Whirlpool or any Brand nam. Their number after changing would look like this 231.65489 near floor behind door seal and near kick plate.I will help you if you let me know, Thanks Sea Breeze
Nov 13, 2009 | Kenmore 57182 / 57184 / 57188 / 57189 Side...
Fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 10, 2009 | Refrigerators
Fridge warm at top cold at bottom
If the fan is no coming on inside the freezer this will need to be fixed soon. Both fans upper and lower must run while compressor runs. Inside the fresh food compartment close the damper on bottom left side next to the paned drawer. If this does not help send more cold air to the top let me know as there could be something else causing the dampers not to open and close properly.
Thanks, Sea Breeze
May 28, 2009 | GE Refrigerators
Kenmore refrig. 13 yrs old. frost in back of freezer, compressor not kicking on. some cold air, but won't keep food cold enough model: 9552710
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Refrigerators
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ed22rf cools poorly on non freezer side.
Check condenser for dirt or dust, check back wall of freezer section for frost, if you find frost there is a defrost problem. Frost buildup on the surface of the back wall indicates that the coil inside the back wall is frozen over. Inside the back wall on the coil are heaters which the timer energizes to defrost at certain intervals. These heaters could have an open circuit, the defrost thermostat could be open, or the timer could be malfunctioning. To test the timer manually you can rotate the clutch head screw clockwise untill you hear one click. The heaters should come on and defrost for 18-22 minutes. The refrigerator should return to cooling after that time. If it does not automatically restart turn the screw once more to a second click and it should start.
Jun 08, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Freezer gets real hot
It sounds like the defrost termination t/stat (located on the freezer coil) and the defrost timer have both been jammed on by the storm. A quick way to check is to locate the defrost timer (every model seems to locate it in a different position) look for a round plastic cover around 15mm diameter inside the fridge or freezer, remove the cover and rotate the timer clockwise until you hear a firm "click" then plug the fridge into the power & see if it starts (some defrost timers can also be located near the kick plate or near the compressor well) if the compressor starts (I'm such it will) replace both of these parts.
Cheers John.
Apr 01, 2008 | Whirlpool 25.2 cu. ft. Side-by-Side...
Kenmore side by side refrigerator and freezer is not cold
It most likely did not fix itself and will give trouble again in the future. If you will post the complete model number I will try to tell you what to look for if it happens again and the most likely components to cause the problem. If it has knobs that you turn for the temp control, you probably have a sticking thermostat that started working when you bumped it with the rag, but it could also have been a defrost timer that was sticking, or it could just have been a coincedence that it started working at that time.
Oct 27, 2007 | Refrigerators
Refrigerators Logo
634 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
