Question about Ingersoll Power Force By Rand PF260 Automotive Spray Gun Hvlp
Hi, i have an powerforce by ingersoll rand pf1300 electric air compressor and my pressure switch is burnt out, i want to replace it but dont know how? any ideas
  • 3,740 Answers
It is not difficult.
Old switch
Remove the nut holding the cover in place and lift the plastic cover off. Inside there are 4 wire connections 2 line in black and white wire and 2 line out and a ground. Just make sure that you mark the in cord and the out cord. Once you have disconnected the wires use a wrench to unscrew the switch from the stand off tube to the pressure tank.
New switch
Apply a small amount of teflon pipe tape to the stand off pipe thread (Maybe 3 wraps) and install the new pressure switch.
If the old pressuer switch had an electrical box connector transfer the box connector to the new pressure switch.
Route the line in (power) and line out (Motor) cords making sure they pass through the hole in the side of the pressure switch. If the new switch has any rubber grommets make sure the wires are routed through the grommets.
Connect the line in and line out cords to the screws on the switch.
Install the plastic cover and retaining nut.
Test compressor by letting it run until the motor is shut off by the pressure switch.
If it shuts off too early (low pressure) open the cover and on the vertical threaded stem adjust it clockwise to increase pressure.
If pressure is too high adjust if counter clock wise.
The pressure switch usually comes with a data sheet. Follow instructions on the sheet.
Thanks for using FixYa.
Kelly
Posted on May 04, 2010
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
I have an Ingersoll Rand 2340L5 and need to know how to have it come on when it gets down to 120 instead of 100
Change the settings on the pressure switch. Brad Brown has a good description of the pressure switch
Nov 22, 2011 | Ingersoll Rand - Rand Type - 30...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
Air leaks from pressure switch after compressor builds full pressure
if its leaking steady from the unloading valve on the pressure switch after the compressor stops you have a bad check valve!replace it and youl be fine,dont forget to depressurize your tank before!!!!! and use teflon tape on the treads to avoid air leaks when you replace it!
Jan 20, 2011 | Ingersoll Rand Single Stage Electric...
I just bought a used ingersoll rand ss3L3 and need to know how to adjust the pressure regulator switch. Also how to set the high and low limits.
if you want more pressure out your hose use the outlet pressure regulator. if you want more or less air put in the tank you can try to adjust the pressure switch. different models are adusted in different ways. there may be a screw between the points that make contact. adjust it up or down to see the direction you need to go. some of these switches won't let you adjust or id they do it won't be much.
Sep 02, 2010 | Ingersoll Rand Single Stage Electric...
My ingersol rand compressor shuts down on low unload sump
check minimum pressure check valve on top of separator cover.
Jun 30, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Cuts off with no reason
hi mate when the reach there working pressure e.g.150psi/10bar they shut off and then when the pressure drops to a pressure of e.g. 100 psi 7 bar they automatically start back up and pump back upto they working temperature or if it dont start at all it could either be a faulty pressure switch or a fualty star delta starter if its 3 phase 415 volts if its 240volt there are only a pressure switch which will be faulty get a sparky in to sort it out there buggers to mess with 415volts 240 volts easy
Jun 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Ingersoll Power Force By Rand PF260 Automotive Spray Gun Hvlp Logo
95 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
