Question about Saeco Incanto Classic Espresso Machine
I have a saeco incanto classic I have tried to descale 2 times and the red light will not go off, is there a reset buttton?
  • 1,089 Answers
Hi
In order for the light to go off, the machine has to stop pumping on its own, both in the descale and the rinse mode. If you stop it before its done it will still be in the descale mode.
Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
Posted on May 09, 2010
On our Saeco Italia we had to run the water tank dry before it would get out of the descale mode. I must have run 6 tanks of water through before we figured this out. You only need to run it without water until the water light comes on. Any longer and I assume you could damage the pump. I'm not possitive, but I think you have to run the tank dry when it has the descale solution in it and when you have clean water for the rinse.
Posted on May 18, 2010
Two steday green lights and red is on
the red light mean that you have to descal machine
Nov 15, 2013 | Saeco Incanto Classic Espresso Machine
Saeco S class Incanto Classic was working, but now no steam at all. The pump sounds like it is trying to pump, but cuts out after a coupl of seconds, hot water light comes on, red water light flashes, and...
Check the end of the steam wand and parnello, if both are clear, then descale machine, that might unblock the tubes feeding the booster boiler and the steam wand if it doesn't then you will have to do it manually.
Mar 06, 2010 | Saeco Incanto Classic Espresso Machine
Machine won't prime
Try lifting the water tank, then setting it back in place, and then priming the machine.
Jan 15, 2010 | Saeco Incanto Classic Espresso Machine
How do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Oct 26, 2009 | Saeco Incanto Classic Espresso Machine
How to stop saeco incanto while doing a task
You really do not want to do that but you can always open the door and the machine will reset itself except in descale mode, it just goes back to the start.
Oct 06, 2009 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto
Hi
Jul 01, 2009 | Saeco Incanto Classic Espresso Machine
Saeco incanto deluxe
Try descaling it manually- by adding the descaler into the tank, letting the machine warm up and then open the water spout to fill one cup at a time. wait 15min. in between. Also clean brew group and grinder.
Jun 10, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
537 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
