Question about Williams 2509612 Ceramic Mid-Size Heater
Hi. I have 15kw TMC srl patio heater. Pilot ok, main burner low
Hi. I have 15kw TMC srl patio heater. The pilot lights immediately and burns well. The main burner sounds like its working, but only warms a little - never seems to get up to speed. No smell of gas. Thanks
3 Suggested Answers
co7196
  • 3433 Answers
SOURCE: Charmglow Patio Heater
The yhernocoupler would snuff the pilot if bad. What ignites the overhead burners? and what regulates the overhead gas supply? Look into this. Too much gas will not light as easily as proper balance gas and air. Even more so in a tower type heater.. Turn the gas on low and the pilot should grab it. Good luck
Posted on Jun 10, 2009
heatman101
  • 43501 Answers
SOURCE: my patio heater model tmc s.s.l the pilot works
That may have an oxygen sensor on it and if it gets dirt in it that will happen...
Take apart the pilot assembly and blow it out with high pressure air and then reassemble it...that should fix it...
heatman101
Posted on Apr 21, 2010
Pilot gos out when burner shuts down wall furnice
Usually thats a sighn of a bad thermocouple,thats the copper tube that goes from the gas valve to the actual pilot assembly it senses that the pilot is burning and allows the main burner to light. If there is no pilot lit the bur will not light. Its there to keep you home from exploding from a release of gas with no pilot. The good thing is that most ofthem are universal and most water heaters use the same one. And you can buy one for a water heater at lowes or home depot for about ten bucks. If you get one thats longer than the origional thats ok because you can just coil it in a circle just be carefull and dont kink the tube,if you do kink it you must get another one. even if you straighten it.
It wont work. Hope that gets you going and warm.
Jan 12, 2013 | Vanguard International Blue Flame - Medium...
The pilot seems to light but then when I turn the knob to ignite the main burner, the pilot goes out. Is there a technique to clean the igniting assembly?
let the pilot light burn for a few min and get hot after this try slowly moving the knob over to full burn. Sometimes it just need to heat up.
Feb 14, 2011 | Endless Summer 233000 Open Flame Patio...
Pilot burnes yellow and stays lighted when I turn the may burner on its on for about 30 sec. then goes out pilot and burner
You may be low on gas in the tank and there's not enough pressure and/or volume of gas to sustain it. Also, try carefully cleaning the burner elements.
Jan 19, 2011 | Blue Rhino ES200209 Open Flame Gas Patio...
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
My patio heater model tmc s.s.l the pilot works and when i try to turn the nob to get the burner working the pilot goes out have you any i dear whats wrong with it
heatman101
Apr 21, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Have Endless Summer patio heater. I got the burner to run but after 3-5 minutes the heater shuts down. Also having problems getting the unit to fire after lighting pilot light Maybe thermo coupler?
It could be the thermocouple, but you have to take the head apart to replace it. If you got the main burner to fire, then the thermocouple is probably ok. Try changing the regulator, easy to do and not to expensive. If that doesn't work, try taking the head apart and cleaning the pilot and main burner orifices, do both while you are in there. If you are not comfortable doing this, hire someone.
Oct 21, 2009 | Endless Summer 2009 Open Flame Patio...
The pilot light does not stay on so heater won't light.
to thermocouple where the pilot light sits is either dirty/carbon out of alignment flame not burning on it correctly or damaged/broken which would mean replacement
Oct 19, 2009 | Uniflame Patio Heaters Stainless Steel...
Jun 05, 2009 | Coleman (5040B750) Patio Heater
Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
May 27, 2009 | Endless Summer Blue Rhino 235000...
Williams 2509612 Ceramic Mid-Size Heater Logo
409 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
