Question about Bosch 24 in. SHU43 Built-in Dishwasher
Water in Dishwasher Bottom
After a cycle, the dishwasher drains. After the water drains, water slowly (over hours/night) seeps back into the bottom, the water level rising above the mesh filter on the bottom.
Make: Bosch
Model: SHU43C07UC/17
  • Bosch Master
  • 2,605 Answers
Hello Richard, Welcome to Fixya ! You've come to the right place. The problem you're experiencing unfortunately is a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic, apwagner etc. Do a search for part # 1105846 at repairclinic, you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Goof luck. Macmarkus :)
Posted on May 04, 2010
Bosch dishwasher does not drain.
Posted on May 22, 2010
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
When the cycle finishes, there is water in the bottom of the dishwasher this begins to smell
there is some kind of clog in the drain system. clean the screen in the dishwasher, there gets a build up of food, or misc stuff in there. it is probably draining, but slowly.
the dishwasher usually has a pump that pumps the water out with force, but if clogged it will be slowed down and when the cycle stops there will be water left in bottom
hope this helps
rick
Jul 15, 2011 | Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Hi, If the drain hose is attached under the sink, make sure that the drain hose is looped higher then the outlet it is attached to.
Most model will hold a small amount of water after draining to keep the seals moist.
I hope this helps.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Dishwashers
Frigidaire Dishwasher Problem
by the sounds of it.i think the water inlet valve that lets water into the machine has gone faulty leaving water slowly seep into the machine, you could either replace this valve..or a cheaper solution if you can access the rear of the machine most water supplies would have a small value installed on the incomming supply,you could simply turn off the water till the next time u need to use it.
Jun 28, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Sears Kenmore dishwasher drains and then fills back up.
you have a nearly-clogged u-tube near the connection to your house drain piping. clear the clog out.
May 31, 2007 | GE 24 in. GSD4020Z Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
849 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
