Question about Dryers
Hotpoint dryer dryer not heating up and it is telling me to do filter care my wife lost the manual so i dont know how to do it..
  • 25 Answers
There should be a small door on the top, side , or just inside the door with a removable screen that you clean off. Pull the dryer out and check the vent hose as well making sure that this is not clogged as well.
Posted on Mar 26, 2008
Replacement dryer for recall dryer has no manual. Can you help?
Can you please provide the model number of your Hotpoint Dryer? Thanks!
Apr 18, 2016 | Hotpoint Washing Machines
Ctd80 hotpoint dryer panel flashing dryer not working
Filter at bottom of machine needs pulling out and cleaned on a regular basis. This is a common fault and the lights is telling you to clean the filter. It is a large filter that unclips at the bottom front of machine. Remove two small screws from the front of the filter located left and right and gently remove the front plate. Once removed you will see a metal filter clogged with clothing debris. Clean with cotton buds and a damp cloth till clean. replace all parts and you should have it working once again with a good heat source as well. Every 2-3 months is sufficient to keep it cleaned. Hope this helps.
Feb 27, 2014 | Hotpoint Dryers
I have a Miele T9800 dryer and it stopped working and the vent/filter check light came on. I checked the filter and vent and both are clear and removed the rear cover and made sure the heating element...
Hi - it makes me wonder as why we always tend to do things first prior to seeking the right/correct advice.
A T9800 Miele is not your everyday cheap dryer as you will know - the questions is have you still got your user Manual and if you do - have you read it carefully - it will tell where the problem lies and how to clean it.
I cannot grasp the fact that you would remove the rear access panel for a heater bank to check the resetable over temperature unit.
The machine clearly indicated a vent/filter error not a heat error - I know at this moment you have and are swearing & calling me names...
I will let you cool down a little ....................and I will tell you what you should have done instead of removing that panel Ok?
Jul 16, 2011 | Miele T9800 Electric Dryer
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
Jun 14, 2011 | Hotpoint Dryers
Hotpoint Aquarius CDT00 reverse action tumble dryer. Spins but no heat. Empted water and cleaned filter.
I have exactly the same problem, I am searching desperately for a solution. I really dont wont to buy a new one!
Jan 05, 2011 | Hotpoint Dryers
My hotpoint aquarius dryer is not got any heat
Most likely reason is failure of thermostat/s or heater element.
As you do not specify model, Ir is difficult to tell you exactly where to locate them, but generally speaking they are at the rear of the dryer.
Hope this helps.
Jan 12, 2010 | Hotpoint Dryers
Filter on WT960
hi, in the uk the filter is behind a flap on the bottom/front of the machine, be careful as when you undo it some water will leak out, hope this helps
Feb 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer does not dry clothes
On the top of the heater box there is a thermal fuse that blows if the dryer overheats, on this model it could occur if the air circulation fan is faulty, or the condenser valve is faulty, alternatively the sump hose filter may be blocked, only a closer inspection of these items will determin which the problem is.
Nov 13, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Not heating up
I would check the thermo fuse in the back of dryer.. its on the burner towards the top.. use omh meter and check if its good. If you dont have a meter, if very careful and just hook wires togeter and tape so nothing touches and will not short out by touching anything, bypass switch JUST to see if switch is bad! Replace it if bad
Sep 05, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
