Question about Water Heaters
Hotpoint water heater leak
Water keeps running from discharge valve
  • 349 Answers
Its a pressure relief valve on water heater you can take it loose and replace it.
It's 3/4 threads and it may take a big adjustable or pipe wrench to break loose Lowes or Home Depot have them in stock .
They go bad sometimes
Posted on May 05, 2010
Testimonial: "Thanks I appreciate it!"
How do I re seal around the pressure release valve on a ge8s06aag water heater
The model number you have doesn't match anything and you don't say exactly where on the valve it is leaking so you are going to get my straightup advice. If the valve is leaking around the pin or lever it probably should be replaced for safety purposes. On the off chance that it got fiddled with by accident, or the tank is pretty old and has gotten corroded or you have mineral deposits, you can flush it.
Make sure the discharge pipe is properly connected and will discharge hot water outside safely, raise the lever on the release valve, by pulling the lever to the up position, make sure water is flowing out the discharge pipe and then re-close the valve by lowering the lever back to the flat position, flat side down. Be careful the lever may have gotten a little warm. If it is still leaking around the pin, it needs to be replaced. If the valve is leaking from the base where it attaches to the tank, the discharge pipe will have to be "sweated" off, the valve removed and re-doped which is not usually a job for a homeowner.
Sep 11, 2014 | Water Heaters
Leaking drain faucet
turn off gas. turn off water. drain water heater by connecting garden hose to drain valve and place discharge end somewhere that that will safely handle the water.(sink, outside,floor drain). lift temp. relief valve to allow air into the tank so a vacuum doesn't prevent draining. carefully remove the leaking valve by using a pipe wrench. counterclockwise to loosen. there may be a little water left in the bottom of the tank, so be ready with a wet vac. buy a new valve at your local hardware store, along with a roll of teflon tape. wrap the teflon tape around the threads in a clockwise rotation. don't use more than three or four wraps. replace the valve by turning in a clockwise rotation. tighten till snug. don't overtighten! if it still leaks a bit at the threads, you can tighten a bit more.
Mar 09, 2014 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Gas water heater leaking
2 major leak areas. The first is theT&P valve. If it is leaking, you may be having problems keeping the heater hot enough for your hot water needs. Would need additional symtom(s).
If problem is water on the floor, it would be smart to purchase a new heater. Your water bill will be going higher as long as the leak is not dealt with. You will also be paying more for your natural gas because the heater will be running longer.
If your heater is 15 - 20 years old, i would definately buy a new one. We can help if you send model # and brand name.
Feb 02, 2013 | Water Heaters
Is my water heater leaking?
You have water leak that you can hear running water.
Could be broken pipe under house.
Could be water running out of tank at TP valve.
Turn off all water taps and put ear against each pipe at tank.
If TP valve is leaking, then replace TP valve.
If pipe is broken under house, then call contractor.
Copy following links for troubleshoot walk-thru.
http://waterheatertimer.org/images/Ear-against-pipe-200.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
Aug 28, 2012 | Reliance 606 Series 40 Gallon Electric...
I have a 21v407 Rheem water heater that is leaking from the top relief valve. The leak i believe, is from under the valve. what is this problem. and how do u drain this thing?
Shut off the water supply valve over the heater. Shut off the electric or gas to the heater.
If you have any house or basement water valves below the level of the heater, open them and open a valve that is higher to vent it.
If necessary, open the drain at the bottom of the heater and using hose or buckets, lower the level below the relief/thermostatic valve. Be careful, the water is hot and softens even heavy hoses.
Once the water level is down, unthread the downtube (if there is one) from the discharge of the relief valve, unthread the relief valve from the heater and either dope/tape the threads or replace the relief valve.
Write back with any questions.
Sep 09, 2011 | Rheem Water Heaters
Have a GE GG40T6A gas hot water tank. Leaking really bad out of the pressure relief valve. It is a rental property, gas was off to the house (tenants moved out in the night). When the gas company turned...
12 year old water heater is getting near the end.
Some tanks last 20 years, but that's the exception.
To find exact age of your brand water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Leaking TP valve:
1) Lift TP lever and gently lower back into position to see if that stops leak.
Occasionally something gets stuck in the valve.
2) Sometimes water heater temperature gets turned up because heater is not producing as much hot water as before, and higher temps cause TP to release pressure because of overheating.
Dial temperature down to 120 degrees.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) If steps above don't fix problem, replace TP valve >> TP valves have 125 or 150 degrees rating >>> older tank shouldn't be running above 125 because higher temps cause more pressure on tank, so thermostat should be lower than 125 degrees TP rating.
Buy replacement TP at any hardware store + a roll of teflon tape to seal pipe threads.
Turn gas control to pilot ... this will keep pilot lit but burner will not fire.
Let water cool, and then drain some water out of tank.
If TP valve is on side of tank, then open drain on side of tank and drain water until it is lower than valve level. Open bathtub spigot to let air into line.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Be careful around water that is higher than 120 degrees F >> you can get burned quickly >> apply cold water to any burn.
Use pipe wrench and unscrew TP valve counterclock-wise.
Install new TP and put teflon tape on threads.
Re-fill tank completely and open tub valve on hot side until water is running >> then turn gas control back to original position.
Do not fire up any water heater before tank is completely full of water or this could damage tank.
To read more preventative information about water heater leaks and age problems:
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Nov 24, 2010 | General Electric GE SmartWater Household...
Leaking pressure relief valve
what is the water pressure on the cold side? You may need to install a pressure reducing valve at the water heater inlet to reduce inlet pressure and keep pop off valve from opening when not needed.
Feb 27, 2010 | Emerson Part UWL Chrome Ultrasystem water...
Gas water heater is discharging out the pressure relief valve? what problems do i have?
The water heater is over heating the water, possibly boiling it and causing steam pressure build up. The thermostat is not sensing the temp to shut off the flame. It would be wise to either have a repairman come out or replace the heater. If pressure builds too high and the relief valve cand keep up ,theer could be a rupure of a water lineSoooooooooooo, turn the gas off and git er done.
Nov 09, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
I keep having to top up with water every few days, but no leaks to be found, the pressure drops down to less than one and the boiler turns off, please can you help,
what kind of heater combi? if combi you may be pressurising boiler to high ie over 1 bar boiler may be blowing off through release valve check discharge pipe
Oct 28, 2009 | Water Heaters
Hotpoint waterheater leak
The 'overlflow line" is actually the discharge pipe from a safety valve. You should call a plumber to check it out. It could be simply the safety valve going bad but there could be other problems causing the problem. What ever you do, DO NOT plug the line because this could cause the water heater to explode.
Jun 11, 2009 | Water Heaters
Water Heaters Logo
215 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
