Question about Whirlpool RMC275PD Microwave Oven
Whirlpool GMC305PD -- Thee beeps and won't start
Light on Microwave went out and when I was figuring out how to change the bulb the microwave stopped working. I suspected door closure micro switches were bad so I changed the switch on the top left side of the door and the two switches on the top right side of door. Did not fix or change the problem. Still the same. All the lights and numbers come on normally. Is there another door switch I missed?? Is there some sort of reset? I changed the bulb and it still doesn't work either....
  • 1 more comment
  • Scabo Mar 26, 2008
    Can you tell me where to find the fuses?
    I checked and there are three fuses. 1) Line fuse; 2) magnetron thermal fuse and 3) cavity thermal fuse. Which fuse would it be? I would think if the line fuse was bad that the microwave would not have power but everything is working except the start button gives three beeps. If the lline fuse was bad there would be no power (hence no beeps at all). Am I missing something?
  • Anonymous Apr 16, 2008
    WHERE ARE THE FUSES LOCATED?
You need to replace the 20 amp line fuse (listed as a 15 amp on the tech sheet for the microwave/oven combo which can be found on top of the unit once you take off the control panel. The unit needs to be pulled out and quite a bit of the metal protective panels have to come off to get to the fuse, which is located on the right side of the microwave. We had the same problem and when i googled the problem, I read that it had to do with the door switches. We found out (by having a repairman out) that it has nothing to do with the door switches and once you replace the fuse, the light works and the microwave work. Hope this helps someone.
Posted on Aug 31, 2009
I have the same problem and it sounds like a fuse too, now if only I knew which fuse and where to find it...can anyone help?
RB
Posted on Sep 02, 2008
Worked great!! I bought a new fuse for $4.50 and replaced it and the microwave works again....light is still not working but I'm ok with that!! Thanks!!!!
Posted on Mar 27, 2008
  • 185 Answers
The 3 beeps are telling you that your fuses are blown
Posted on Mar 26, 2008
  • william ludolph Mar 27, 2008
    its the themal fuse its usally white and skinny and has 2 connectors to it
New unit used 3 days. Microwave beeps and screen goes to menu, or set time screen. Sometimes changes the date all by itself. Does this in the middle of the night all night long.
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
Nov 05, 2012 | Whirlpool GH7208XR Convection / Microwave...
Hello, The inside light went out in my CM8155XJ Microwave. For the life of me I can't figure out how to access the bulb. Any info you may be able to share would be greatly appreciated. Thank You very...
the whirlpool free helpline is 1-800-253-1301
I don't think that there are any parts of the oven that you can service, however if you are feeling very brave then you could try removing the screws on the back
May 04, 2011 | Whirlpool GM8155XJ Convection/Microwave...
Hello, I have the whirlpool microwave oven, Model ...
logic board needs replacement if it cannot be reset.
Jun 17, 2017 | Whirlpool MH3185XP Microwave Oven
All the light blew out, the electric still works, but the oven won't heat food
Hi, my living room light has stopped working, When i turned it on one of the little bulbs went pop and light stopped working although all electric and other lights still work. I tried the bulb in a different light and it still works as well?? I also took light off to check for loose wiring etc but all seems to be fine. Can you help? Thanks!
Oct 04, 2009 | Whirlpool Accuwave Microwave Oven
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
Panasonic genius microwave light bulb replacement The bulb on my Microwave model RMC275PD blew and no the microwave won't start, if I replace the bulb will the microwave work again? Thanks Richard
Yes definitely that should be working fine again since it only stop working when the bulb blew,so go ahead and replace the bulb so you can use it again...
Hope that helps.......
Aug 27, 2008 | Whirlpool RMC275PD Microwave Oven
Microwave Ovens Logo
606 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
