I have been using my OKI C5600 Duples since 1960! Since 8:30 today 1. I have tried to return to --- Paper A$ - Landscape, 2 Sided Printing, Fliop short edge but afyet clickinf OK the two pictuire windows show me on the left a selection of "Tiled" boxes and on the right the print preview box shows me half a page! 2 six hours of fidsdling and read your comprehensive guide, I cannot get rid of the "Tiled option and need your help! Please make it simple I am in my 80's
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you are using Windows, then you’ll need to select the whole document by pressing control (Ctrl) and ‘A’ (alphabet) simultaneously and left click on ‘No border’ option at the top of the document in the command area. Now again select the document by pressing control (Ctrl) and ‘A’ (alphabet) simultaneously and left click on ‘View’ and select normal. Please also left click on ‘File’ option at the top left of command area and then click on ‘Page setup’ option and check that in ‘Layout’ option the top and bottom margins are selected at 0.5” each. You can also copy the document and paste on a new file and then see the results. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 04, 2010
Can i print both side with canon lbp 2900 printer
This model Canon printer does not have a duples unit and therefore cannot print double sided prints.
You can print double sided but you must print one page at a time.
Please click on this link and follow my instruction to do double sided printing.
http://www.fixya.com/support/r7325259-double_sided_printing_using_single_sided
Aug 27, 2011 | Canon LASER SHOT LBP-2900 Printer
Strange clicking noise OKI C5600
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
Jun 02, 2010 | OKI C5400 Laser Printer
Does the Lexmark X9575 print automaticly 2 sided with no manual feed. I have a 15 page document doulbe sided. How do I print this without babysitting the printer. Thank you
Your model supports automatic duplex printing using letter and A4 sizes ONLY. If you want to print two-sided documents on another type or size of paper, use the manual duplexing method.
1) With a document open, click "File" > "Print..."
2) Click "Properties" or "Preferences" or "Options" or "Setup" depending on your system
3) Click the "Advanced" tab
4) From the "2-Sided Printing" area, select the 2-Sided Printing option and then select either the "Sideflip" or "Topflip" option (sideflip is the setting most often used)
5) From the drop-down box, select Automatic.
6) You will see an "Extend dry time" option, which allows extra drying time between sides when you are printing on both sides of the paper. The Automatic 2-Sided Printing option affords enough time for the ink to dry on supported paper types in average air humidity. Under conditions of high humidity, or if the normal drying time does not allow the ink to dry completely, you should select Extend dry time.
7) Click <OK> to close any printer software dialogs that are open. This will take you back to the General Print screen.
8) Click "Print"
Note: To return to single-sided printing, return to the Advanced tab. From the 2-Sided Printing area, clear the 2-Sided Printing check box.
Jan 14, 2010 | Lexmark X9575 InkJet Printer
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
How do i put paper in the bypass feed of the OKI C5600 printer? I can't find the bypass tray or how to put thicker paper through the machine.
The bypass feeder or multipurpose tray as OKI call it is situated above the standard or 1st cassete paper tray.
It is usually hidden. Ther is a door door with an handle. Pull the handle to open it and then extend the tray.
For images and instructions on how to feed the paper, check page 13 and following pages of the User Manual you can download from here:
http://www.c5600.co.uk/library/documents/c5600/C56uEN1.pdf
Also, I leave you the link to the support homepage for your copier. On the left side of the page there are several useful inks (to download drivers, software and documents, how-tos, explanation of errors, etc.):
http://www.c5600.co.uk/index.asp
Aug 19, 2009 | Ricoh Aficio 250 Copier
My suddenly prints every other page in landscape. What is the problem? Tom
It prints in portrait then landscape, portrait then landscape and so on. I use a laptop and desktop with this printer and both are doing it. 2 sided print has not been selected.
Aug 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP 3600dn Duplexing Issue
Manual 2-sided printing. Most of the supported media sizes and types listed for printing from tray 1 can be manually duplexed. Do not use the 2–sided printing feature on transparencies, envelopes, or labels.
I found this note in the 3600 service manual. Maybe it will help.
Mar 06, 2009 | HP LaserJet 3600dn Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Hi oki c5600. printing A4 size labels succesfully until printing image with large areas of colour. "Smearing" gets progressivly worse as the doucuments goes through
that means that your ink and the label materials are not compatible. you may need to use less ink, or a more porous label facing.
Aug 20, 2008 | OKI Office Equipment & Supplies
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
