Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron Srs BBE stand by light blinking and do not turn on
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
ONE: Unplug it for at least 4 hours. That is what we call a hard reset.
TWO: If the hard reset does not help, then it will need further diagnostics.
The following bulletin may be of help in your learning about what is going on. Please refer to it below. Then let me know if you need further assistance.
Have a great day,
Cleggsan
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on May 31, 2010
I replaced jungle IC301but it didn't work, still blinking,and IC is heating..what could be the problem?
Posted on Apr 20, 2013
Is the 2004 sony trinitron srs bbe model nomber kv32fs120 analog or digital ?
Try this: http://tv.manualsonline.com/manuals/mfg/sony/fd_trinitron_wega_kv32fs120_kv36fs120.html
Apr 27, 2015 | Sony Televison & Video
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Tv will not turn on but the stand by light is on and the tv make a click when you press the power button and the tv goes back to stand by mode. Any help would be great.
It sounds like it might bbe a fuse. Take the back off and check the fuse for open,(blowed). Replace it with the same amps. ...Hope this helps...
Mar 07, 2010 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony Trinitron---Blinks 9 times, won't come on!
A specific model number will probably get you more specific
help.. but if you check around the internet by model number
you will likely be presented with some SERIOUS PART opportunities...
The FASHING LIGHT means you have a hard fault in the power circuits...
The number of flashes is mean to point you to a specific area...
I gave all my big flat screens away in favor of the new
HD stuff... (certainly less reliable than those Sony sers...
Shopjimmy might be a great place to call... but the MODEL NUMBER is a MUST.
TV Parts Universal TV Stands DLP Chips ShopJimmy
May 18, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stand By timer light continues to blink on Sony Triniton TV
That problem comes up when one or both of the convergence IC's are burnt ... it normally has an "STK" number on it screwed onto some large aluminium heatsink ..... however if you venture to change it get back to me ... I'll try to guide you through ....
May 23, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony WEGA Trinitron SRS BBE 32'
Please reply couple of questions about TV to guess what could be wrong.
1- How many times standby light blinks, there would be interval of 3 seconds in blinks so count pause to pause.
2- Please intimate exact model of TV, written on sticker pasted at back of TV. That will help me to check its schematics.
Hit " add a comment" button to reply.
Thanks.
May 03, 2009 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Trinitron KV-32fs120 Does Not Turn On
i have a unvirasal remote how do iget the codes for it
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
4,110 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
