Question about ASUS Ai Lifestyle M2N-E (ASKU49311) Motherboard
Trying to connect chasis usb to motherboard, but do not know which ports to plug in to
  • 478 Answers
Plug into the yellow set of pins, follow the way the plug has no wire leading inside the plug, which will go where there is no pin in the grouping and there u have it your plugged in
Posted on May 05, 2010
Dell laptop not turning on
Check all the USB ports to see if they are damaged. If any of the pins in the USB ports are touching the chasis then this will case a short circuit and stop it turning on. With the power disconnected, move the pins away from the chasis using a small ascrew driver and make suer they are not touching each other.
Jul 30, 2013 | Dell Computers & Internet
Hello! my problem is that my two USB ports is blown. Now I want to connect more USB port on the motherboard via cable, but none matches the port that the USB or sb_link, jp1... Can you tell me which port...
You will need to get a usb expansion card. These can be found at Best Buy, Newegg.com, tigerdirect.com, pc-connection.com etc...
Some manufactures ship with newer motherboards a usb expansion slot using the motherboard jumper configuration but your motherboard must first be able to support this type of expansion.
I recommend the pci usb expansion. They plug into your PCI slot and give you 2-4 extra USB slots in the back of your computer.
Mar 01, 2011 | Quadrant Slot 1 QM-6VABX2 (QM-6VABX2-1664)...
Chassis fan not detect
there are two ways a chasis fan can be connected....
1)to the motherboard(it should detect)
2)directly to the SMPS(it wont detect)
if its connected to the SMPS, then remove and plug to the fan port for external fan on your motherboard.......i wud personally advice you to leave it as it is if the fan is working properly......moreover its not necessary for the chasis fan to be monitored....HOPE IT HELPED................DO VOTE IF IT HELPS.........
Jan 18, 2011 | Compaq (283983-001) Motherboard
Find the correct connections on motherboard for usb ports
frist you have some port of usb on front pannel of cpu . connect the wire of usb . u can plug the usb card from on board pci slot then you need to enable your usb in bios
Apr 10, 2010 | EliteGroup K7S5A Pro Motherboard
Problem with USB port on Asus P5KPL-AM SE Motherboard
Older motherboards have USB 1.1 ports;
newer motherboards have USB 2.0 ports,
which are over 10 times as fast.
It is Windows (not your motherboard) that should do the "Plug-and-Play" thing for devices connected to your USB port(s).
Note that some devices are USB 2.0, and will *NOT* work when plugged-in to a USB 1.1 port.
Either get a newer motherboard, or get a PCI add-on card that adds USB 2.0 ports.
Sep 10, 2009 | ASUS P5KPL-AM SE Motherboard
HP D530 SFF CHASIS FAN NOT DETECTED
tell me the wright way to remove 512 chassis fan error i am very depressed on this
Mar 17, 2009 | HP Compaq d530 SFF PC Desktop
Power surge on hub port a usb device has exceeded the power limits of its hub port there is nothing connected to my computer
I don't know how old your system might be or how many USB controllers it has on the motherboard, but understand this...
Theoretically, one USB port can support up to 999 "daisy chained" devices.
With that said...the way a USB port is implemented on a motherboard, manufacturers enable two or four ports to be working off of one USB interface. Those ports you see on the front of your computer are most likely connected to just one USB interface on the actual motherboard and that's why you always see computers with USB ports located together in pairs.
With that in mind, you're USB ports are connected to what is referred to as a "hub"(that motherboard interface), which only outputs so much power. If one device or many devices attached to this "hub" exceed the power output of this "hub" then it will either back down to USB 1.1 speeds or it won't function at all. That is why some USB accessories require their own wall adapter, because the USB can't supply all the necessary power for it.
So one of two things has happened, either your USB port is fried or you introduced a new USB item to the "hub" that surpasses the power requirements of what your USB hub can output once you plug in your mp3 player.
You can troubleshoot by unplugging all un-necessary USB equipment and try only that port again. My assumption is that the USB hub is fine but the actual usb port you use might be damaged.
Good luck.
Mar 12, 2009 | Acer Aspire One PC Notebook
Plugging in a USB port.
You have an A side and B side, or 1 and 2. Starting from pin 1, usually has an arrow pointing to it, the wires should read as follows: 1= A/1 +5vac 2= B/2 +5vac
3= A/1 -D 4= B/2 -D
5= A/1 +D 6= B/2 +D
7= A/1 ground 8= B/2 ground
9= no pin 10= no connection
Aug 28, 2008 | Intel Motherboard
Usb problem
You shouldn't need the USB driver 2.0 from mercury because windows installs this with SP2. Suggest you un-install what you installed from mercury & update your version of windows (completley), through "Windows Update". Once windows is all updated & you have finished with a reboot. Plug your pen drive in a opened usb port. Open windows explorer. Scroll down & you should see an icon (left side of explorer), thats named like, Removable Disk. Give windows time to see the device. After a few minutes if your pen device does not show up try another usb port. One you know does work. If after a couple of minutes go by & you still don't see the device listed in explorer I would say the device is defective. Your Mp4 uses a cable to connect to the usb. Try connecting to another PC's usb port. It is possible the cable is dirty or bad.
Jan 13, 2008 | Mercury P4VM800M7 Motherboard
Open Questions:
ASUS Ai Lifestyle M2N-E (ASKU49311) Motherboard Logo
26 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
